Updated on 2025-12-18 GMT+08:00
Container Asset Overview
What Is a Container Asset?
In a container environment, there are often dozens, even hundreds, of containers running on a cluster node. As containers increases and the runtime changes, it becomes difficult to manage complex container asset conditions, which may leave blind spots and expose risks.
HSS container asset management collects information about clusters, nodes, containers, images, and container fingerprints to help you clearly learn the asset status of the container environment, improve O&M efficiency, and comprehensively manage risks.
Container Asset Collection Items
Information about clusters, nodes, containers, images, and container fingerprints (including accounts, open ports, processes, software, auto-started items, web applications, web services, web frameworks, websites, middleware, and databases) can be collected. For details, see Container Asset Collection Items.
Table 1 Container fingerprint collection items
Asset Type
Collection Description
Collected Information
Clusters
Collect information about the cluster list, workloads, services, and pods, helping you learn the cluster status.
  • Cluster list: cluster information, version, cluster type, cluster status, available/total nodes, and creation time
  • Workloads:
    • Deployments/StatefulSets and DaemonSets: workload name, status, number of pods, namespace, image name, cluster, cluster type, and creation time
    • Common tasks: workload name, status, number of pods, namespace, completion time, image name, cluster, cluster type, and creation time
    • Scheduled task: workload name, status, task triggering, number of running tasks, namespace, completion time, image name, cluster, cluster type, and creation time
  • Services:
    • Services: name, endpoint name, access mode, service IP address, namespace, cluster, cluster type, and creation time
    • Endpoints: name, namespace, cluster, associated with service or not, service name, cluster type, and creation time
  • Pods: name, namespace, cluster, cluster type, node, pod IP address, status, and creation time
Nodes
Collect information about cluster nodes and independent nodes to help you learn about the node status.
  • Cluster nodes: server name and IP address, cluster information, OS, node status, and agent status
  • Independent nodes: server name and IP address, OS, node status, and agent status
Collect container information to help you learn the container running status and identify abnormal containers.
Container name, cluster information, status, pod, cluster type, image name, and creation time
Images
Collect information about local images, repository images (including SWR, Harbor, and Jfrog), and CI/CD images to help you manage image sources and versions.
  • Local images: image information, image tag, image size, service name, number of associated containers, and number of components
  • Repository images: image information, image repository name, image tag, and image size
  • CI/CD images: image information, CI/CD name, image tag, and image size
Accounts
Collect container system accounts to help you identify suspicious accounts.
Account name, number of associated containers, server name and IP address, login permission, root permission, user group, user directory, user startup shell, and container ID
Open ports
Collect ports in the container system to help you identify risky ports. For details about the risky ports defined by HSS, see High-risk port list.
Local port, protocol type, number of associated servers, server name and IP address, listening IP address, status, PID, program file, server port, and container ID
Processes
Collect processes running in the container system to help you detect abnormal processes (such as hidden processes and unknown hash processes).
If a process has been inactive for 30 consecutive days, it will be automatically removed from the process list.
Process path, number of associated containers, server name and IP address, startup parameter, startup time, the user who ran it, file permission, PID, file hash, and container ID
Software
Collect information about the software installed in the container system using the package manager (such as rpm and dpkg) to help you count software assets and identify insecure software versions.
Software name, number of associated containers, server name and IP address, software version, and container ID
Auto-started items
Collect auto-started services, startup folders, pre-loaded dynamic libraries, Run registry keys, and scheduled tasks in the container system, helping you detect abnormal auto-started items in time and quickly locate Trojans.
Auto-started item name, type, number of containers, server name and IP address, path, file hash, the user who ran it, and container ID
Websites
Collect information about web content directories and externally accessible websites, helping you comprehensively learn the website structure and access paths and preventing unauthorized access.
Information about the following websites can be collected: Linux-based Apache, Nginx, and Tomcat.
External domain name, number of containers, server name and IP address, external port, URL, web directory, directory permission, directory UID, last directory modification time, SSL certificate, certificate issuer, certificate user, certificate issuing time, certificate expiration time, associated PID, and container ID
Web frameworks
Collect information about the development framework used by web pages to help you identify framework vulnerabilities.
The following types of web frameworks run on Linux and support data collection:
  • Java language framework: Struts, Struts 2, Spring, Hibernate, WebWork, Quartz, Velocity, Turbine, FreeMarker, fleXive, Stripes, Vaadin, Vert.x, Wicket, ZKoss, Jackson, Fastjson, Shiro, MyBatis, Jersey, and JFinal
  • Python framework: Django, Flask, Tornado, web.py, and web2py
  • PHP language framework: Webasyst, KYPHP, CodeIgniter, InitPHP, SpeedPHP, ThinkPHP, and OneThink
  • Go framework: Gin, Beego, Fasthttp, Iris, and Echo
Web framework name, number of containers, server name and IP address, version number, path, associated PID, process path, and container ID
Collect the JAR packages loaded by the Java process in the container system and the JAR packages that the Java process depends on, helping you understand the service support components and identify abnormal components.
Middleware name, number of containers, server name and IP address, version number, path, associated PID, process path, and container ID
Web services
Collect details about the software that provides web content access for external systems, helping you learn the website hosting service settings and prevent vulnerabilities and unsafe settings.
Data can be collected from the following web services: Apache, Nginx, Tomcat, WebLogic, WebSphere, JBoss, Wildfly, and Jetty.
Web service name, number of containers, server name and IP address, version number, software directory, directory permission, directory UID, last modification time of the directory, configuration file, associated PID, process path, and container ID
Web applications
Collect details about the software that is used to push and publish web content, helping you learn the content transmission channels and prevent application vulnerabilities.
Data of the following web applications can be collected: PHPMailer, PHPMyadmin, DedeCMS, WordPress, ThinkPHP, BigTree, JPress, Jenkins, Zabbix, Discuz!, and ThinkCMF.
Web application name, number of containers, server name and IP address, version number, software directory, directory permission, directory UID, last modification time of the directory, configuration file, associated PID, process path, and container ID
Collect details about data storage software, helping you manage important data storage media and prevent database vulnerabilities and unsafe settings.
Data can be collected from the following types of databases: MySQL, Redis, Oracle, MongoDB, Memcache, PostgreSQL, HBase, DB2, Sybase, Dameng database management system, and KingbaseES database management system.
Database name, number of containers, server name and IP address, version number, software directory, directory permission, directory UID, last modification time of the directory, configuration file, associated PID, process path, and container ID
Container Asset Collection Methods
Container asset information can be collected automatically or manually. You can set the automatic collection period or manually collect fingerprints as required.
  • Automatic collection
    After the container edition is enabled for a server, HSS container security automatically collects all asset information. For details about the collection types and intervals, see Table 2. The start time of the automatic collection period is the time when the agent is successfully installed.
    Collection frequency can be customized for middleware, web frameworks, kernel modules, web applications, websites, web services, and databases. For details, see Asset Discovery.
    Table 2 Asset types and frequencies of automatic collection
    Asset Type
    Automatic Collection Frequency
    Clusters
    Automatic collection every 24 hours
    Nodes
    • Cluster nodes: Data is automatically collected every 24 hours.
    • Independent nodes: Data is automatically collected after the agent is installed.
    Images
    • Local images: After the agent is installed, data is collected for the first time. After that, data is automatically collected every 2.5 hours.
    • Repository images: After the SWROperatePolicy and CCEOperatePolicy permissions are granted, the service automatically collects image information in the early morning every day. For details, see Authorization.
    • CI/CD image: Data is automatically collected during CI/CD project building.
    Accounts
    Automatic collection every hour
    Open ports
    Automatic collection every 30 seconds
    Processes
    Software
    Data is collected when the container is started. After the container is stopped, the collected data is automatically cleared.
    Auto-started items
    Websites
    Once a week, at 04:10 a.m. every Monday (with a random delay of up to 1 hour)
    Web frameworks
    Web services
    Web applications
  • Manual collection
    To check the latest asset fingerprints, use the one-click collection function provided by HSS container security to collect container fingerprints.
Notes and Constraints
