Viewing RocketMQ Consumer Connection Addresses
The consumer connection addresses are the message consumption client addresses. The connection addresses of a connected client can be viewed on the console.
A consumer's connection addresses can be viewed only when the consumer is connected to a RocketMQ instance.
- A consumer group has been created and there are consumers in the group.
- A topic has been created.
- Log in to the console.
- Click in the upper left corner to select a region.
Select the region where your RocketMQ instance is located.
- Click and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
- Click a RocketMQ instance to go to the instance details page.
- In the navigation pane on the left, choose Instance Diagnosis.
- For Consumer Group, select the group whose consumer connection address you want to view. Then click Start Diagnosis.
- Locate the row containing the desired diagnosis record, and click View.
- In the Results area, view the consumer connection address.
Figure 1 Consumer connection addresses
