Help Center/ Distributed Message Service for RocketMQ/ User Guide/ Managing Consumer Groups/ Modifying RocketMQ Consumer Group Configurations
Updated on 2024-12-23 GMT+08:00
After creating a consumer group, you can modify its configuration as required.
Prerequisite
A consumer group has been created.
  1. Log in to the console.
  2. Click in the upper left corner to select a region.
    Select the region where your RocketMQ instance is located.
  3. Click and choose Middleware > Distributed Message Service for RocketMQ to open the console of DMS for RocketMQ.
  4. Click a RocketMQ instance to go to the instance details page.
  5. In the navigation pane, choose Consumer Groups.
  6. Modify consumer group parameters in either of the following ways:
    • In the row containing the consumer group whose parameters you want to modify, click Edit.
    • Click a consumer group and then click Edit in the upper right corner of the consumer group details page.
  7. Modify consumer group parameters by referring to Table 1.
    Table 1 Consumer group parameters
    Maximum Retries
    Maximum number of times that messages are resent upon retrieval failures.
    Value range: 1–16
    Broadcast
    Indicates whether messages are broadcast.
    If this option is enabled, each message is retrieved by all consumers in the consumer group. If this option is disabled, each message is retrieved by only one consumer in the consumer group.
    Orderly
    This parameter is mandatory when the RocketMQ instance version is 5.x.
    If this option is enabled, consumers consume messages in sequence.
    Orderly consumption ensures sequential consumption by message sending. In this case, earlier messages are consumed before later messages
    Description of the consumer group.
    0–200 characters
  8. Click OK.
