Help Center/
Huawei Cloud Flexus/
User Guide/
FlexusL/
Managing Backups/
Associating a FlexusL Instance with a Server Backup Vault
Updated on 2024-10-08 GMT+08:00
You can associate a FlexusL instance with a server backup vault on the CBR console, rather than the FlexusL console.
FlexusL instances only support server backup vaults.
- Associate a FlexusL instance server with a vault.
- On the CBR console, choose Cloud Server Backups from the left navigation pane and click Buy Server Backup Vault. On the displayed page, select a FlexusL instance server you want to back up. For details, see Purchasing a Server Backup Vault.
- Associate a FlexusL instance server with an existing vault. For details, see Associating a Resource with the Vault.
- View the vault details. For details, see Querying a Vault.
