Viewing a Vault
You can set search criteria for querying desired vaults in the vault list.
At least one vault has been created. For details, see Buying a Cloud Server Backup Vault.
Viewing Vault Details
- Log in to the CBR console. Click
in the upper left corner and select a region. - On the Vaults tab, view basic information about all vaults. Related parameters are described in the following table. Figure 1 Vault list
Table 1 Basic information about a vault Parameter
Name/ID
Name and ID of the vault. Click the vault name to view details about the vault.
Type
Vault type, which can be backup vault or replication vault.
- A backup vault stores backups of servers, file systems, and disks.
- A replication vault stores replicas of backups.
Status
Vault status. Table 2 describes the vault statuses.
Backup Locking
Whether backup locking is enabled for the vault.
- Enabled: If backup locking is enabled, it cannot be disabled.
- Disabled: Backup locking is disabled for the vault.
Specifications
Vault specifications, which can be common server backup vault or database server backup vault.
- A common server backup vault stores backups of non-database servers.
- A database server backup vault stores backups of database servers.
Backup Data Redundancy
Redundancy policy for backup data.
- Single-AZ: Backup data is stored in a single AZ, with lower costs.
- Multi-AZ: Backup data is stored in multiple AZs for higher reliability.
Used/Total Vault Capacity (GB)
Capacity used by the backups in the vault. It shows the space used by backups and the total vault capacity.
For example: If 20/100 is displayed, 20 GB has been used out of the 100 GB vault capacity.
Associated Servers/File Systems/Disks
Number of servers, file systems, and disks associated with the vault. You can click the number to view details of associated resources. The associated capacity shown on the details page is the total capacity of all the resources that have been associated with this vault. If an associated resource is deleted, the resource is still counted in the number of associated resources.
Enterprise Project
Enterprise project that the vault has been added to.
If you need to modify the enterprise project of a vault, go to the Enterprise Management page to move the vault from the original enterprise project to a new one. For details, see Managing the Enterprise Projects of Vaults.
Billing Mode
Billing mode of the vault, which can be Yearly/Monthly or Pay-per-use.
- Yearly/Monthly is a prepaid billing mode. You are billed based on the subscription duration you specify. This mode is ideal when the resource use duration is predictable and costs less than pay-per-use billing.
- Pay-per-use is a postpaid billing mode. You are billed based on your resource usage and you can add or delete resources anytime. Fees are deducted from your account.
- On the Vaults tab, set filter criteria to view specific vaults.
- Select a value from the status drop-down list to query vaults by status. Table 2 describes the vault statuses.
Table 2 Vault statuses Status
Attribute
All statuses
All vaults are displayed if this value is selected.
Available
A stable state
A stable state after a vault task is complete.
Most operations can be performed on a vault in this state.
Locked
An intermediate state
An intermediate state displayed when a capacity expansion, billing mode change, or specifications change is in progress.
If a vault is in this state, you can perform operations, such as applying a policy and associating servers, file systems, or disks. However, the following operations are not allowed on such a vault: expanding the vault capacity, changing the billing mode, and changing the vault specifications. Once those operations are complete, the vault status will become Available.
Deleting
An intermediate state displayed when a vault is being deleted.
In this state, a progress bar is displayed indicating the deletion progress. If the progress bar remains unchanged for an extended time, an exception has occurred. Contact customer service.
Frozen
A stable state
A vault enters the Frozen state if it is in the retention period because of overdue payment on a yearly/monthly package or pay-per-use billing, or if its resources violate regulations.
If the resources are frozen due to arrears, the state will become Available after you pay off the outstanding balance, and the resources can then be used normally. If you do not pay off the outstanding balance in time, the system automatically deletes the frozen resources after the retention period expires. If the resources are frozen due to security reasons, contact customer service.
Error
A stable state
A vault enters the Error state when an exception occurs during task execution.
You can click Tasks in the navigation pane to view the error cause. If the error persists, contact customer service.
- Search a vault by its name or ID.
- Click Search by Tag in the upper right corner to search for vaults by tag.
- On the displayed Search by Tag page, enter the tag value and key that are available in the drop-down lists and click
. The added tag is displayed under the text box. Click Search in the lower right corner. - You can add a maximum of 10 tags by clicking
. They will be applied together for a combined search. - You can click Reset in the lower right corner to reset the search criteria.
- Click the name of a specific vault to view vault details. Figure 2 Viewing vault details
For RDS backups, the vault list displays only the Name/ID, Status, Type, Used/Total Vault Capacity, Billing Mode, and Enterprise Project. Currently, you cannot view the vault details. To view the instance details, click the instance name on the Instances tab to go to the RDS console and then view the instance details there.
- The values of used capacity and backup space are rounded off to integers. CBR will display 0 GB for any backup space less than 1 GB. For example, there may be 200 MB backup space used, but it will be displayed as 0 GB on the console.
- After changing the name of the resource associated with the vault, you need to perform an automatic or manual backup again to synchronize the change.
