Updated on 2026-11-26 GMT+08:00
Deleting a Vault
If an enterprise or individual no longer needs a vault to store backup data, they can delete or unsubscribe from it to release resources and reduce storage costs. This scenario applies to the following situations: service system offline, backup policy adjustment, vault migration to another region, and clearing unnecessary vaults created in test or temporary environments.
The operation varies depending on the billing mode of the vault. Pay-per-use vaults can be deleted, while yearly/monthly vaults need to be unsubscribed from.
Once you delete a vault, all backups stored in it will be deleted and cannot be restored. Ensure that backup data is no longer needed or that necessary data has been migrated before deleting a vault.
  • There is at least one vault.
  • The vault is in the Available or Error state.
  • Backups in a hybrid cloud backup vault have been deleted from both on-premises data center and the cloud.
  1. Log in to the CBR console. Click in the upper left corner and select a region.
  2. Find the target vault and choose More > Delete in the Operation column. All backups stored in the vault will be deleted once you delete a vault.
    Figure 1 Deleting a vault
  3. Click OK.
    After deletion, the system displays the result in the upper right corner. You can return to the vault list. If the vault does not exist anymore, the deletion is successful.
Unsubscribing from a Yearly/Monthly Vault
If you no longer need a yearly/monthly vault to store backups, you can unsubscribe from the vault. For details about the unsubscription rules, see Unsubscription Rules.
Method 1
  2. Click the Vaults tab and locate the target vault. Click More > Unsubscribe in the Operation column.
  3. Complete the unsubscription as prompted.
    You can return to the vault list. If the vault does not exist anymore, the unsubscription is successful.
Method 2
  2. Click Billing in the top navigation bar to go to the Billing Center page.
  3. Choose Orders > Unsubscriptions to view the yearly/monthly vaults that you purchased.
  4. Select an unwanted vault and click Unsubscribe from Resource.
    Figure 2 Unsubscribing from a resource package
    After the unsubscription, check the in-use resources that can be unsubscribed from. If the target vault does not exist anymore, the unsubscription is successful.
