Querying Custom Parameters in the Profile List
Run the following command to query custom parameters in the profile list of KooCLI. The query result can be output in a table or in JSON or TSV format. By default, the query result is output in JSON format.
hcloud configure list --cli-custom=true
"current": "test",
"profiles": [
"name": "default",
"custom": {}
"name": "test",
"custom": {
"password": {
"value": "****",
"isEncrypted": true
"projectId": {
"value": "06810000000000000000000000f89d2e",
"isEncrypted": false
Encrypted custom parameter values are anonymized.
Use --cli-query to filter the query result, and use --cli-output to specify the output format. The default output format is JSON. In the following example, all custom parameters of a profile named test are queried, and the query result is output in JSON format:
hcloud configure list --cli-custom=true --cli-query="profiles[?name=='test'].custom" --cli-output=json
"password": {
"isEncrypted": true,
"value": "****"
"projectId": {
"isEncrypted": false,
