Yum Command Parameters
Command format: yum <command> [option]
Parameter |
Description |
help |
Displays help information. |
updateinfo |
Displays summary of package updates. |
upgrade |
Installs package updates. |
check-update |
Checks for available package updates. |
Parameter |
Description |
-h, --help, --help-cmd |
Displays command help information. |
--security |
Displays available security updates. |
--advisory ADVISORY |
Specifies specific advisories. This parameter can be used together with updateinfo, upgrade, and check -update. Multiple packages are separated by commas (,). |
--cve CVES |
Specifies specific CVEs. This parameter can be used together with updateinfo, upgrade, and check -update. Multiple packages are separated by commas (,). |
--sec-severity {Critical,Important,Moderate,Low} |
Specifies specific security levels. This parameter can be used together with updateinfo, upgrade, and check -update. Values in the brackets can be any combination of security update levels. |
Use the yum --help command to obtain more information.
