Updated on 2026-07-10 GMT+08:00
OSMT Command Help Information
  • Run osmt -h to display the OSMT help information.
    [root@localhost SOURCES]# osmt -h
    usage: osmt [-h] {update,rollback,remove,config,job} ...
    positional arguments:
        update              update packages
        rollback            rollback last upgrade
        remove              remove backup files in store path
        config              modify config file by command line
        job                 handle upgrade task.
    options:
      -h, --help            show this help message and exit
    Table 1 OSMT parameters
    update
    Upgrades the OS or updates the RPM packages.
    rollback
    Rolls back the OS or RPM packages.
    remove
    Deletes the backup files from the storage path.
    config
    Queries or modifies the configuration file.
    job
    Queries or manages the upgrade tasks.
    -h, --help
    (Optional) Provides help information of the osmt command.
  • Run osmt update -h to display the help information about the OS or RPM package updates.
    [root@localhost SOURCES]# osmt update -h
    usage: osmt update [-h] [--nosignature] [-s] [--all] [--security] [--version] [-a] [-p  PKGS [PKGS ...]] [-e  EXCLUDE_PKGS [EXCLUDE_PKGS ...]] [-v  RELEASEVER] [-r  REBOOT_CONFIG]
                       [-b BETWEEN] [-j] [-c]
    optional arguments:
      --nosignature         ignore the signature of packages
      -s , --show           show updateinfo
      --all                 show all pkgs which can update, 'osmt update --show --all'
      --security            show security pkgs which can update
      --version             show all version can update to
      -a , --auto           auto update use config file
      -p  PKGS [PKGS ...], --pkgs PKGS [PKGS ...]
                            specify the packages to upgrade
      -e  EXCLUDE_PKGS [EXCLUDE_PKGS ...], --exclude_pkgs EXCLUDE_PKGS [EXCLUDE_PKGS ...]
                            specify the packages not to upgrade
      -v  RELEASEVER, --releasever RELEASEVER
                            specify the release version to upgrade
      -r  REBOOT_CONFIG, --reboot_config REBOOT_CONFIG
                            you can choose between always, never or a specific time. 'always': reboot os after update ends if need. 'never': never reboot os automatically. '<specific time>':
                            reboot at specified time, format like "2020-02-02 2:02:02".
      -b BETWEEN, --between BETWEEN
                            start upgrade time and end upgrade time, format like: '2020-02-02 2:02:02','2020-02-02 4:02:02'
      -j , --job            run upgrade in background.
      -c, --check           check upgrade task.
      -V, --verbose         show more log to screen
      -o, --preinstalled-only
                            upgrade preinstalled packages only
      -t, --retry           retry previous upgrade action
      --nocheck             do not check before upgrade
      -f, --fix             auto fix some system problems checked out
      --upgrade_history     query upgrade/rollback records
    Table 2 osmt update
    -h, --help
    Provides help information about the osmt update command.
    --nosignature
    Specifies not to filter the RPM packages to be updated by package signature.
    -s,--show
    Displays available upgrade or update information.
    • --all: displays all RPM packages to be updated.
    • --security: displays the security packages to be updated.
    • --version: displays the version to be upgraded to.
    -a,--auto
    Specifies the RPM package update method. This parameter is mutually exclusive with -v, -p, and -e.
    -p,--pkgs
    Specifies the whitelisted RPM packages to be updated. This parameter is mutually exclusive with -v and -a.
    -e,--exclude_pkgs
    Specifies the blacklisted RPM packages that will not be updated. This parameter is mutually exclusive with -v and -a.
    -v , --releasever
    Specifies the target HCE version.
    -r, --reboot_config
    Specifies the restart configuration.
    • always: restarts the OS after the update if some package updates are only applied after a restart. If there are no such packages, the OS will not restart.
    • never: does not restart the OS after the update.
    • <specific time>: specifies a specific restart time. If some package updates are only applied after a restart, the OS will restart at the specified time after the update. The restart time is in the format of "2020-02-02 2:02:02". If there are no such packages, the OS will not restart.
    -b, --between
    Specifies the start time and end time of automatic updates using osmt-agent. The value is in the format of "HH:MM-HH:MM".
    If the end time is smaller than the start time, the update period covers two dates. For example, 22:00-05:00 indicates an update period from 22:00 on the current day to 05:00 on the next day.
    -j, --job
    Performs the upgrade using background processes.
    -c, --check
    Checks the system status before the upgrade. This parameter is optional. The system also performs the check before executing the upgrade.
    You are advised to add -c to the update command to perform the check. For example, before running osmt update -a to perform the upgrade, run osmt update -a -c to check the system status.
    -V, --verbose
    (Optional) Displays detailed upgrade information.
    (Optional) Only the RPM package list in /etc/osmt/preinstalled.list is upgraded. This parameter is valid only for version upgrade.
    -t, --retry
    (Optional) Retries the upgrade.
    --nocheck
    (Optional) No checks will be performed before the upgrade. The upgrade starts directly.
    -f, --fix
    (Optional) Some environment problems are automatically resolved during the version upgrade.
    --upgrade_history
    (Optional) Queries upgrade or rollback records.
  • Run osmt rollback -h to display the help information about the OS or RPM package rollbacks.
    usage: osmt rollback [-h] [-r  {never,always}] [-V] [-t] [--nocheck]
    optional arguments:
      -r  {never,always}, --reboot_config {never,always}
                            whether to reboot after rollback
      --nocheck             do not check before rollback
      --check_status        check rollback status
    Table 3 osmt rollback
    -h, --help
    Provides help information about the osmt rollback command.
    -r, --reboot_config
    -V, --verbose
    (Optional) Displays detailed process logs.
    -t, --retry
    (Optional) Retries the rollback.
    --nocheck
    (Optional) No checks will be performed before the rollback. The rollback starts directly.
    --check_status
    (Optional) Checks the rollback status. If the exit code is 0, the rollback is successful. If the exit code is 1, the rollback is abnormal.
  • Run osmt config -h to display the help information about configuration item modification or query.
    usage: osmt config [-h] [-k KEY] [-v VALUE] [-V]
    optional arguments:
      -k KEY, --key KEY     key of config item
      -v VALUE, --value VALUE
                            value of config item
    Table 4 osmt config
    -h, --help
    Provides help information about the osmt config command.
    -k, --key
    Specifies the keys to be queried or modified.
    -v, --value
    Specifies the values of the keys to be modified.
    -V, --verbose
    You are advised to run osmt config to modify the configuration file. Any modification made to the file using a method other than osmt config may lead to abnormal OSMT functions.
  • Run osmt job -h to display the help information about task management.
    usage: osmt job [-h] [-s] [-c] [-d DELAY] [-y]
    optional arguments:
      -s, --show            show task info.
      -c, --cancel          cancel current task.
      -d DELAY, --delay DELAY
                            delay task
      -y, --yes             never ask for yes.
    Table 5 osmt job
    -h, --help
    Provides help information about the osmt job command.
    -s, --show
    Displays background task information.
    -d, --delay
    Allows for postponing the pending restart task. For example, to postpone the task for 1 hour and 50 minutes, set the value to "1:50:00".
    -c, --cancel
    Cancels the current job.
    -y, --yes
    Considers by default that the user agrees the operation.
    -V, --verbose
