- Product Bulletin
User Guide
- Usage Overview
- Selecting HCE as the Public Image When Creating an ECS
- Changing an OS to HCE
- Migrating an OS
- Upgrading HCE and RPM Packages
- Security Updates for HCE
- Obtaining the openEuler Extended Software Packages
- Creating a Docker Image and Starting a Container
- Tools
- Kernel Functions and Interfaces
- xGPU
- Configuring the Repositories and Installing Software for HCE
- What Do I Do If CentOS Linux Is No Longer Maintained?
- Does Huawei Cloud Have a Migration Solution for CentOS?
- How Do I Install the MLNX Driver?
- How Do I Enable SELinux on an ECS Running HCE?
- How Do I Change the OS Name on the Console After the OS Is Migrated?
- How Are Huawei Cloud EulerOS, EulerOS, and openEuler Different from One Another?
- How Do I Enable WireGuard in Kernel and Install wireguard-tools?
- How Do I Save the User Credential Information for Logging In to Docker Like What Docker CE Does?
- What Is OOM? Why Does OOM Occur?
- How Do I Handle IPVS Errors?
- Why Can't HCE Obtain an IPv6 Address After IPv6 Is Enabled for an ECS?
- How Do I Set Auto Log Using TMOUT?
- Best Practices
Show all
Rolling Back RPM Packages
Run osmt rollback --reboot_config always to roll back RPM packages. They can only be rolled backup to the last update.
In the command, --reboot_config always is optional. You must use it if there are RPM packages in need_reboot_rpms updated in the last update.
If --reboot_config always is not specified, you need to manually restart the OS so that the rollback of packages in need_reboot_rpms can be applied.
Use the latest OSMT. You are advised not to roll back OSMT using OSMT.
