- Product Bulletin
User Guide
- Usage Overview
- Selecting HCE as the Public Image When Creating an ECS
- Changing an OS to HCE
- Migrating an OS
- Upgrading HCE and RPM Packages
- Security Updates for HCE
- Obtaining the openEuler Extended Software Packages
- Creating a Docker Image and Starting a Container
- Tools
- Kernel Functions and Interfaces
- xGPU
- Configuring the Repositories and Installing Software for HCE
- What Do I Do If CentOS Linux Is No Longer Maintained?
- Does Huawei Cloud Have a Migration Solution for CentOS?
- How Do I Install the MLNX Driver?
- How Do I Enable SELinux on an ECS Running HCE?
- How Do I Change the OS Name on the Console After the OS Is Migrated?
- How Are Huawei Cloud EulerOS, EulerOS, and openEuler Different from One Another?
- How Do I Enable WireGuard in Kernel and Install wireguard-tools?
- How Do I Save the User Credential Information for Logging In to Docker Like What Docker CE Does?
- What Is OOM? Why Does OOM Occur?
- How Do I Handle IPVS Errors?
- Why Can't HCE Obtain an IPv6 Address After IPv6 Is Enabled for an ECS?
- How Do I Set Auto Log Using TMOUT?
- Best Practices
Show all
Automatic Update Using osmt-agent
The osmt-agent service periodically checks whether there are available RPM package updates and updates them automatically. You can configure how often to check updates and when to perform the update.
- Run the following command to ensure that the value of auto_upgrade in the osmt.conf file is True:
osmt config -k auto_upgrade -v True
- Run systemctl status osmt-agent.service to check whether the osmt-agent service is started.
- If the Active value is active (running), osmt-agent is started.
- Otherwise, run systemctl start osmt-agent.service to start osmt-agent.
- Run the desired command to configure when or how often to perform the updates:
- To configure a time window for automatic updates:
osmt config -k auto_upgrade_window -v "auto_upgrade_window"
auto_upgrade_window: defines the start time and end time of automatic updates using the osmt-agent service. The value is in the format of "HH:MM-HH:MM".
If the end time is smaller than the start time, the update period covers two dates. For example, 22:00-05:00 indicates an update period from 22:00 on the current day to 05:00 on the next day.
For example, run the following command to configure a time window starting from 23:00 on the current day to 01:00 on the next day:
osmt config -k auto_upgrade_window -v "23:00-01:00"
- To configure the interval between two automatic updates:
osmt config -k auto_upgrade_interval -v auto_upgrade_interval
auto_upgrade_interval: defines the minimum interval between two automatic updates, in days.
For example, run the following command to configure automatic updates every other day:
osmt config -k auto_upgrade_interval -v 1
