Editing the Properties of a Graph
The Property tab displays information about the properties of the selected vertices and edges. You can edit the properties of a single vertex or edge.
The procedure is as follows:
- Right-click a vertex/edge on the canvas and choose View Property from the shortcut menu. The Property tab is displayed on the right, showing the properties of the selected vertex/edge.
If the selected vertex has multiple labels, you can click the drop-down box next to the label to view the properties of other labels.
Figure 1 Properties
- Click
next to the property to edit it.
- Click
after you finish editing.
Click Edit All at the bottom of the property area to edit all the displayed properties. Click Save All.
In the Property tab, only the properties of a single vertex or edge can be edited. In the Schema tab of the metadata area, you can add or delete all properties of a tag, as described in section Editing Schema.
