Displaying a Graph in 3D View
The 3D view of a graph provides you intuitive analysis experience.
Usage restrictions of the 3D display function:
- Memory edition: Only supports displaying the results of the PagePank algorithm, PersonalRank algorithm, DSL queries, Cypher queries, and Gremlin queries.
- Database edition: Only supports displaying the results of Cypher queries.
The results of other algorithms or queries can only be displayed in 2D mode.
The following example shows how to view results of the PagePank algorithm in the 3D view graph:
- In the algorithm area on the left of the graph editor, select the PagePank algorithm and set required parameters.
- Run the algorithm. After the analysis is complete, you can view the result in the canvas.
- Click
in the upper left corner of the canvas to switch to the 3D view.
Figure 1 3D view of the result
