Updated on 2024-11-04 GMT+08:00
Preparing Metadata
Preparing Metadata on a Local PC
You need to prepare a metadata file on your PC and import the file to GES for subsequent graph analysis.
The metadata files you want to import must meet the following requirements:
  1. A maximum of 50 metadata files can be imported.
  2. The metadata files must be in XML format.
(Optional) Importing Metadata to OBS
You can upload a prepared metadata file to an OBS bucket to import it to GES.
The procedure is as follows:
  1. Log in to the OBS console and create an OBS bucket. If you already have a bucket, ensure that the OBS bucket and GES are in the same region. For details about how to create a bucket and upload files, see Creating a Bucket and Uploading an Object.
  2. Upload the prepared file to the OBS bucket by referring to Uploading a File. The metadata file must be in XML format.
