Help Center/
Graph Engine Service/
User Guide/
Managing Created Graphs/
Increasing the Number of Concurrent Read-Only Requests of a Graph
Updated on 2025-08-14 GMT+08:00
Graph expanding increases the maximum number of concurrent read-only requests that can be processed, without changing the graph size.
- Currently, Ten-thousand-edge and Ten-billion-edge graphs cannot be expanded.
- Graphs cannot be resized after expansion. If you want to resize and expand the graph, resize the graph before you expand it.
The procedure is as follows:
- In the navigation pane, choose Graph Management. On the displayed page, locate the target graph and choose More > Expand in the Operation column.
Figure 1 Expanding a graph
Only a running graph can be expanded.
- In the displayed dialog box, set the number of nodes to be added.
Figure 2 Select the number of nodes to expand
- Click OK. The graph status changes to Preparing for expansion. After a few minutes, the graph status changes to Expanding. Once the graph is successfully expanded, the graph status changes to Running.
Parent topic: Managing Created Graphs
