Viewing Monitoring Metrics
Cloud Eye monitors the running status of GES. You can view the monitoring metrics of GES on the Cloud Eye management console.
It takes a period of time for transmitting and displaying monitoring data. The GES status displayed in the Cloud Eye monitoring data is the status obtained 5 to 10 minutes before. You can view the monitoring data of a newly created graph 5 to 10 minutes later.
- The graph has been properly running for at least 10 minutes. For a newly created graph, you need to wait for a while before viewing its monitoring metrics.
 - You can only view the monitoring data of graphs that are in the running, importing, exporting, or clearing states.
 - In the navigation pane, choose Graph Management. In the Operation column, choose . The Cloud Eye management console is displayed.
 - On the monitoring page for GES, you can view the figures of all monitoring metrics.
    Figure 1 Viewing monitoring metrics
     - The system allows you to select a fixed time range or use automatic refresh.
- Fixed time ranges include Last hour, Last 3 hours, and Last 12 hours.
 - The automatic refresh interval is 60s, which is used as the user monitoring period.
