- What's New
- Function Overview
- Billing
- Getting Started
- User Guide
Best Practices
- Using Global Accelerator to Speed Up Cross-Border Access to Web Servers
- Using CDN and Global Accelerator to Speed Up Cross-Border Access
- Using Global Accelerator to Speed Up Cross-Border Access to Third-Party On-premises Servers
- Using Global Accelerator to Accelerate Communications Between Cloud and On-Premises Servers and Implement Multi-active DR
- Transferring the Source IP Address of a Client
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Global Accelerator
- Listener
- Endpoint Group
- Endpoint
- Health Check
IP Address Group
- Creating an IP Address Group
- Querying IP Address Groups
- Querying Details of an IP Address Group
- Updating an IP Address Group
- Deleting an IP Address Group
- Adding CIDR Blocks to an IP Address Group
- Removing CIDR Blocks from an IP Address Group
- Associating an IP Address Group with a Listener
- Disassociating an IP Address Group from a Listener
- Region
- Tag
- Log
- Appendix
- SDK Reference
- Can I Use the Ping Command to Test Latency?
- How Will I Be Billed for Global Accelerator?
- How Can I Increase the Global Accelerator Quotas?
- How Can I Use Traffic Dial to Distribute Traffic?
- What Types of Endpoints Can Be Added to a Global Accelerator?
- Can I Use Global Accelerator in an Area That Is Not Listed Among the Acceleration Areas?
- What Are the Statuses and Health Check Results of Endpoints?
- What Should I Do If an Endpoint Is Unhealthy?
- Most Frequently Asked Questions
- Configuring the TOA Module
- How Can I Use Global Accelerator to Enable European Users to Access the Applications Deployed in or Outside the Chinese Mainland (Excluding Europe) Faster?
Modifying an Endpoint Group
You can modify the name, traffic dial, and description of an endpoint group.
- Health check settings of the endpoint group, including whether the health check is enabled, protocol/port, interval, timeout, and maximum number of retries. For details about how to modify the health check settings, see Modifying Health Check Settings.
- Endpoints in each endpoint group, including their weight. For details, see Modifying an Endpoint.
- Log in to the Global Accelerator console.
- Search for the global accelerator by name or ID.
- Click the name of the global accelerator to go to the details page.
- Click Listeners.
- On the right of the page, click Endpoint Groups.
- Locate the endpoint group you want to modify and click Modify in the Operation column.
- Modify the parameters. For details, see Modifying an Endpoint Group.
Table 1 Endpoint group parameters that you can modify Parameter
Name
Name of the endpoint group.
Each listener can be associated with only one endpoint group in a given region.
You can enter up to 64 characters. Only letters, digits, and hyphens are allowed.
Supplementary information about the endpoint group.
You can enter up to 255 characters.
Traffic Dial
The percentage of traffic directed to the endpoint group.
If you increase the traffic dial, more requests will be distributed to this endpoint group.
If you set the traffic dial to 0, no requests will be distributed to this endpoint group.
The weight ranges from 0 to 100.
If a listener has multiple endpoint groups, traffic will be first distributed to the endpoint group with the lowest latency and then to other endpoint groups based on the traffic dial value you set.
- Click OK.
