Help Center/FunctionGraph/User Guide/Configuring Function Flows/Configuring Function a Flow Component/Configuring a Wait Processor
Updated on 2025-08-19 GMT+08:00
The Wait processor controls the current subflow or function to call the next subflow or function after a specified delay.
Notes and Constraints
- Function flows created in Data Workroom (DWR) can only be viewed on the FunctionGraph console; editing and deletion must be done within DWR.
- The Wait processor can be connected to zero or one node that is not start or error handling.
Before using flows, learn about Expression Description and Operators.
Configuration Description
In the flow orchestration area, click the Wait processor and change the value of Latency (s) (the value must be between 0.001 and 86400).
Figure 1 Configuring the Wait processor
