Updated on 2026-08-24 GMT+08:00
Configuring a Subflow Processor
Multiple function flows can be combined as a new flow and reused to avoid repeated orchestration.
Notes and Constraints
Function flows created in DWR can only be viewed on the FunctionGraph console; editing and deletion must be done in DWR.
Configuration Description
On the function orchestration page, click the subflow node and set the parameters by referring to Table 1.
Table 1 Subflow parameters
Subflow
All created flows are displayed in the drop-down list.
Proceed Until Subflow Completed
Enabled by default.
Input Filter Expression
JSONPath expression used to filter the input information of the node.
Output Filter Expression
JSONPath expression used to filter the output information of the node.
