Updated on 2025-08-19 GMT+08:00
Starting a Flow
After configuring a flow, start it to activate the service function.
Notes and Constraints
If you modify the flow configuration, save the changes before starting the flow.
Starting a Flow
- On the function flow orchestration page, click Start in the upper right corner. Alternatively, on the function flow list page, click More > Start.
- On the Start Execution page, specify input or start the flow directly. In this example, select With input. (The input values must be in JSON format.) Figure 1 Starting execution
- Click Execute. A message indicating that the flow is started successfully is displayed in the upper right corner.
