Updated on 2025-08-19 GMT+08:00
FunctionGraph Metrics
Introduction
This section describes the FunctionGraph namespaces, function metrics, and dimensions reported to Cloud Eye. You can view function metrics and alarms by using the Cloud Eye console or calling APIs.
Namespaces
SYS.FunctionGraph
Notes and Constraints
The metrics displayed on the console vary depending on the region. All metrics supported by FunctionGraph are listed here.
Function Metrics
Table 1 Function metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
Monitored Object (Dimension)
Monitoring Period of Raw Data (Minute)
count
Invocations
Number of function invocations.
≥ 0
Count
None
Function
5
failcount
Errors
Number of invocation errors.
The following errors are included:
  • Function request error (causing an execution failure and returning status code 200)
  • Function syntax or execution error
≥ 0
Count
None
Function
5
failRate
Error Rate
Percentage of errors to the total invocations of a function.
0% ≤X≤ 100%
None
Function
5
rejectcount
Throttles
Number of function throttles.
It indicates the number of times that FunctionGraph throttles your functions due to the resource limit.
≥ 0
Count
None
Function
5
concurrency
Concurrency
The number of requests that can be processed concurrently.
≥ 0
Count
None
Function
5
reservedinstancenum
Reserved Instances
Number of instances reserved for running a function.
≥ 0
Count
None
Function
5
duration
Average Duration
Average duration of function invocation.
≥ 0 ms
ms
None
Function
5
maxDuration
Maximum Duration
Maximum duration of function invocation.
≥ 0 ms
ms
None
Function
5
minDuration
Minimum Duration
Minimum duration of function invocation.
≥ 0 ms
ms
None
Function
5
systemErrorCount
System Errors
Number of system errors that occur during function invocation.
≥ 0
Count
None
Function
5
functionErrorCount
Function Error Count
Number of function errors that occur during invocation.
≥ 0
Count
None
Function
5
payPerUseInstance
Elastic Instances
Number of instances used, excluding reserved ones.
≥ 0
Count
None
Function
5
instances
Instances
Number of instances for function invocation.
≥ 0
Count
None
Function
5
duration_p500
Duration (P50)
P50 execution duration of the function.
≥ 0 ms
ms
None
Function
5
duration_p800
Duration (P80)
P80 execution duration of the function.
≥ 0 ms
ms
None
Function
5
duration_p950
Duration (P95)
P95 execution duration of the function.
≥ 0 ms
ms
None
Function
5
duration_p990
Duration (P990)
P990 execution duration of the function.
≥ 0 ms
ms
None
Function
5
duration_p999
Duration (P999)
P999 execution duration of the function.
≥ 0 ms
ms
None
Function
5
memoryUsed
Memory
Memory used by the function.
≥ 0 MB
MB
None
Function
5
functionCost
Resource Usage
Resources used by the function (Memory x Duration).
≥ 0 MB
MB
None
Function
5
instanceUsage
Used Instances
Percentage of the used function instances to the total number.
0% ≤X≤ 100%
None
Function
5
Table 2 Flow metrics
Metric ID
Metric Name
Value Range
Unit
Conversion Rule
totalCount
Number of calls
Total number of executions of workflow.
≥ 0
Count
None
Flow
errorCount
Number of errors
Total number of execution failures of workflow.
≥ 0
Count
None
Flow
running
Number of running
Number of running flows.
≥ 0
Count
None
Flow
rejectCount
Number of times to be restricted
Number of restricted flows.
≥ 0
Count
None
Flow
averageDuration
Run time
Average execution time of workflow.
≥ 0 ms
ms
None
Flow
notifyFailedCount
Number of notify errors
Total number of notified failures.
≥ 0
Count
None
Flow
ExecutionsStarted
Started Workflow Instances
Number of started workflow instances.
≥ 0
Count
None
Flow
ExecutionsSucceeded
Successful Workflow Instances
Number of successfully executed workflow instances.
≥ 0
Count
None
Flow
ExecutionsFailed
Failed Workflow Instances
Number of failed workflow instances.
≥ 0
Count
None
Flow
ExecutionsAborted
Aborted Workflow Instances
Number of aborted workflow instances.
≥ 0
Count
None
Flow
ExecutionsTimedOut
Timed-Out Workflow Instances
Number of workflow instances that timed out.
≥ 0
Count
None
Flow
Dimensions
Key
Value
package-functionname
App name-Function name
Example: default-myfunction_Python
graph_name
Flow name
projectId
Project ID of the tenant
