Simple Message Notification (SMN) Trigger
This section describes how to create an SMN trigger on the FunctionGraph console to trigger function execution when a message is published.
For details about the SMN event source, see Supported Event Sources.
Video Tutorial
This video shows how to use an SMN trigger to trigger a function execution.
As product functions evolve, the GUI may vary. This tutorial is for reference only.
Notes and Constraints
- The regions and runtimes supported for SMN triggers are subject to the console.
- SMN triggers cannot be disabled and can only be deleted.
- You have created a function.
- You have created an SMN topic, for example, smn-test. For details, see Creating a Topic.
Creating an SMN Trigger
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the function to be configured to go to the function details page.
- Choose Configuration > Triggers and click Create Trigger.Figure 1 Creating a trigger
- Set the following parameters:
- Trigger Type: Select Simple Message Notification (SMN).
- Topic Name: Select a topic, for example, smn-test.
- Click OK.
After the SMN trigger is created, a subscription is generated for the corresponding topic on the SMN console.
Publishing a Message to Trigger the Function
On the SMN console, publish a message to the smn-test topic. For details, see Publishing a Text Message. After the message is published, the function is automatically triggered.
Table 1 describes the parameters required for publishing a message.
Viewing the Execution Result
- Return to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click a function to go to the function details page.
- Choose Monitoring > Logs to query function running logs.
Helpful Links
Manage function triggers through APIs. For details, see Function Trigger APIs.
