Versions
FunctionGraph allows you to publish one or more versions throughout the development, test, and production processes to manage your function code. Each version is a complete snapshot of the function at a specific point in time, corresponding to a tag in the code. It includes independent code, configuration, and dependency, making it convenient for rollback, parallel deployment, or feature validation.
After a function is created, the default version is latest. Each function has the latest version.
After a function version is published, you can modify the version configuration as required. However, the code of the version cannot be updated to ensure version stability and traceability.
Notes and Constraints
- You can release a maximum of 20 versions (including the latest version) for a function.
- No triggers, mounting disks, or reserved instances are configured in a new version by default.
- The latest version of a function cannot be deleted.
- If a function version associated with aliases is deleted, the aliases will also be deleted.
- Deleting a version will permanently delete the associated code, configuration, alias, and event source mapping, but will not delete logs. Deleted versions cannot be recovered. Exercise caution when performing this operation.
Publishing a Version
- Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
- Click the name of a function.
- On the Versions tab, click Publish New Version. The new version is published as the latest version. Figure 1 Parameters for publishing a new version
Table 1 Version configuration parameters Parameter
Version
Enter a version number.
The value can contain a maximum of 42 characters, including letters, digits, hyphens (-), underscores (_), and periods (.). It must start and end with a letter or digit. If no version number is specified, the system automatically generates a version number based on the current date, for example, v20220510-190658.
Description of the version. The value can contain a maximum of 512 characters.
- Click OK. The system automatically publishes a version. Then you will be redirected to the new version.
Deleting a Function Version
- On the function details page, select the latest version.
- On the Versions tab page, you can view the created version list.
- Click Delete on the right of the version. In the displayed dialog box, enter DELETE and click OK. Figure 2 Deleting a Version
- Click OK to delete the version.
Helpful Links
Manage function versions using APIs. For details, see Function Version and Alias APIs.
