Updated on 2026-09-11 GMT+08:00
Environment Variables
This section describes how to configure function environment variables on the FunctionGraph console.
Environment variables allow you to pass dynamic parameters to a function without modifying code.
Environment variables can be used in the following scenarios:
  • Environment distinguishing: Configure different environment variables for the same function logic in different deployment environments. For example, use environment variables to configure testing and development databases.
  • Configuration encryption: Configure encrypted environment variables to dynamically obtain authentication information (such as account and password) required to access other services.
  • Dynamic configuration: Configure environment variables for parameters that need to be dynamically adjusted, including query period and timeout, in function logic.
Notes and Constraints
When you define environment variables, FunctionGraph displays all your input information in plain text. For security purposes, do not include sensitive information.
Configuring Environment Variables
  1. Log in to the FunctionGraph console. In the navigation pane, choose Functions > Function List.
  2. Click the name of a function.
  3. Choose Configuration > Environment Variables and click Edit Environment Variable.
    Figure 1 Adding environment variables
  4. On the displayed dialog box, click Add and configure the environment variable information.
  5. Configure Static Encryption for the environment variables. (This step is optional and available only in the LA-Sao Paulo1 region.)
    To use static encryption with KMS, add the permission policy to the agency of the function. The following KMS static encryption modes are supported:
    • functiongraph/default (default): The function automatically creates a default key in DEW.
    • Customer master key (CMK): Select the CMK to encrypt the code. For details about how to create a CMK, see Creating a Custom Key.
    If you select Customer master key (CMK), do not delete the CMK used for function encryption in DEW. Otherwise, the function execution will fail because encrypted data cannot be decrypted.
  6. After the configuration is complete, click OK to save the environment variables.
    After the environment variables are configured, you can use the environment variables in functions. For details, see Application Example of Environment Variables.
Preset Environment Variables
Table 2 lists the preset environment variables.
Table 2 Preset environment variables
Obtaining Method
RUNTIME_PROJECT_ID
Project ID
Obtain the value from a Context interface or a system environment variable.
RUNTIME_FUNC_NAME
Function name
RUNTIME_FUNC_VERSION
Function version
RUNTIME_HANDLER
Handler
Obtain the value from a system environment variable.
RUNTIME_TIMEOUT
Execution timeout allowed for a function
RUNTIME_USERDATA
Value passed through an environment variable
RUNTIME_CPU
CPU usage of a function. The value is in proportion to MemorySize.
RUNTIME_MEMORY
Memory size configured for a function, in MB
RUNTIME_MAX_RESP_BODY_SIZE
Maximum size of the return value (default: 6,291,456 bytes)
RUNTIME_INITIALIZER_HANDLER
Initializer
RUNTIME_INITIALIZER_TIMEOUT
Initialization timeout of a function
RUNTIME_ROOT
Path of the runtime package (default: /home/snuser/runtime)
RUNTIME_CODE_ROOT
Path of the code in the container (default: /opt/function/code)
RUNTIME_LOG_DIR
Path for storing system logs in the container (default: /home/snuser/log)
You can use environment variables to configure which path to install files in, where to store outputs, and how to store connection and logging settings. These settings are decoupled from the application logic, so you do not need to update your function code when you change the settings.
  1. Using environment variable obs_output_bucket, you can flexibly set the OBS bucket used for storing output images.
    Figure 4 Environment variables
  2. Use environment variables in function code.
    In the following code snippet, obs_output_bucket is the bucket used for storing processed images.
    • Non-HTTP functions use context.getUserData ('xxx') to obtain environment variables.
    • HTTP functions use system methods to obtain environment variables. For example, Python functions use os.Environ['xx'], and Node.js functions use process.env.xx. Node.js functions use process.env.RUNTIME_USERDATA to obtain encrypted environment variables.
    • Python
      def handler(event, context):
          srcBucket, srcObjName = getObsObjInfo4OBSTrigger(event)
          obs_address = context.getUserData('obs_address')
          outputBucket = context.getUserData('obs_output_bucket')
          if obs_address is None:
              obs_address = '{obs_address_ip}'
          if outputBucket is None:
              outputBucket = 'casebucket-out'
          ak = context.getSecurityAccessKey()
          sk = context.getSecuritySecretKey()
          st = context.getSecurityToken()
          # download file uploaded by user from obs
          # TODO: Replace with actual implementation
          GetObject(obs_address, srcBucket, srcObjName, ak, sk, st)
          outFile = watermark_image(srcObjName)
          # Upload converted files to a new OBS bucket.
          PostObject(obs_address, outputBucket, outFile, ak, sk, st)
          return 'OK'
    • Node.js
      exports.handler = async (event, context) => {
          let bucket = context.getUserData('obs_output_bucket');
          console.log(bucket);
          const output =
              'statusCode': 200,
              'headers':
                  'Content-Type': 'application/json'
              'isBase64Encoded': false,
              'body': JSON.stringify(event),
          return output;
Helpful Links
