Other Related Tasks
You can view, modify, or delete notification rules and message templates.
- You have obtained the authorization for using SMN.
- You have purchased the professional edition of ESM.
- You have logged in to ESM as an administrator.
- In the upper right corner of the page, click the username and select Notification.
- Perform the tasks described in Table 1.
Table 1 Tasks Task
Viewing notification rules and message templates
View details about notification rules and message templates.
- Select the Notification Rule or Message Template tab.
- View details in the list.
Editing notification rules and message templates
Edit notification rules and message templates.
NOTE:Default templates cannot be edited.
- Locate the row that contains a rule or template and click Edit.
- Modify the parameters.
- Click OK.
Deleting notification rules and message templates
Delete the notification rules and message templates that are no longer in use.
NOTE:Default templates cannot be deleted.
- Locate the row that contains a rule or template and click Delete.
- Click OK.
