Updated on 2025-08-21 GMT+08:00
Managing Resource Tags
EPS allows you to add, modify, and delete resource tags. Batch operations are supported.
You can use tags to mark the usage, ownership, or environment of resources.
For supported services and resources, see TMS and Other Services.
Restrictions and Limitations
  • You can add up to 10 tags to each resource.
  • A key can contain up to 36 characters, including letters, digits, underscores (_), and hyphens (-).
  • A value can contain up to 43 characters, including letters, digits, underscores (_), periods (.), and hyphens (-).
  1. Sign in to the management console.
  2. Choose Enterprise > Project Management in the upper right corner of the page.
    If the screen resolution is low, choose More > Enterprise > Project Management.
    Figure 1 Project Management
  3. On the Enterprise Project Management Service page, click View Resource in the Operation column of an enterprise project. The project details are displayed.
    Figure 2 Viewing resources
  4. Select the target resource in the Resources tab and click Manage Tag.
    You can select one or more resources. You can also select all resources at one time.
  5. On the Manage Tag page, enter the tag key and tag value.
    Figure 3 Managing tags
  6. Click OK and the resource tag is added.
  7. You can modify the tag value by entering a new one or delete the tag by clicking Delete in the operation column.
  8. Click OK. The resource tag is modified or deleted.
    Figure 4 Modifying or deleting a tag
