On this page
Help Center/ Elastic IP/ User Guide/ Elastic IP User Guide/ Cloud Eye Monitoring/ Viewing the Cloud Service Monitoring Dashboard
Updated on 2025-02-21 GMT+08:00
A cloud service dashboard allows you to view all monitoring data of a single cloud service. If you want to collect EIP traffic statistics within a specified period or analyze the bandwidth or traffic usage of EIPs to locate faults, you can view the EIP dashboard and export EIP monitoring data.
  2. Choose Service List > Cloud Eye.
  3. In the navigation pane on the left, choose Cloud Service Monitoring.
    • Viewing the EIP dashboard
      1. On the Cloud Service Monitoring page, click Virtual Private Cloud VPC in the Dashboard column and go to the Details page.
      2. Select Elastic IPs or Bandwidths as required to view detailed data.
    • Viewing the global EIP dashboard
      1. On the Cloud Service Monitoring page, click Global EIP and Bandwidth GEIP in the Dashboard column and go to the Details page.
      2. Select global EIPs or internet bandwidth as required to view detailed data under the Resources and Overview tabs.
  4. On the Overview tab, perform the following operations:
    1. View information under Resource Overview, Alarm Statistics, and Key Metrics. For details, see Table 1.
      Table 1 Three modules on the Overview tab
      Module
      Resource Overview
      You can view the resource data of the current cloud service in the current dimension, including Total Resources, Resources in Alarm, and Resources in Alarm in the Last 7 Days.
      Alarm Statistics
      You can view the total number of alarms in the last seven days, alarms of different severities (critical, major, minor, and informational), top 5 instances by total alarms, and top 5 resource groups by total alarms.
      Key Metrics
      You can view monitoring details of key metrics recommended by the cloud service.
    2. In the upper left corner of the Details page, select Resources to view corresponding monitoring details or select another cloud service to switch to its dashboard.
  5. On the Resources tab, perform the following operations:
    • Click Export Data to export cloud service monitoring data. For details, see How Can I Export Monitoring Data?
    • Locate an instance and click View Metric to view the instance metrics and HTTP status codes.
    • Locate an instance and choose More > Create Alarm Rule to create an alarm rule for the instance. For details about the parameters, see Creating an Alarm Rule.
    • Locate an instance and choose More > View Alarm Rule to view the alarm rules created for the instance.
