Help Center/ Elastic IP/ User Guide/ Global Connection Bandwidths/ Buying a Global Connection Bandwidth
Updated on 2024-09-25 GMT+08:00
This section describes how to buy a global connection bandwidth for communication over the backbone network.
  1. Click in the upper left corner and select the desired region and project.
  2. Go to the Buy Global Connection Bandwidth page.
  3. Configure the parameters based on Table 1.
    Table 1 Parameters required for buying a global connection bandwidth
    Billing Mode
    Mandatory
    Pay-per-use: a postpaid subscription. You are charged based on the usage duration of the global connection bandwidth. Your global connection bandwidth is billed by second, and you are charged for a minimum of 60 seconds each time. If the usage is less than an hour, you are charged based on the actual duration, accurate to seconds.
    Bandwidth Type
    Mandatory
    There are different types of global connection bandwidths that are designed for different application scenarios, including multi-city, geographic-region, and cross-geographic-region bandwidths. The type of a bandwidth cannot be changed after your purchase.
    Select a bandwidth type. For details, see Global Connection Bandwidth Overview.
    You can decide whether to use a geographic-region bandwidth or cross-geographic-region bandwidth based on service scenarios.
    If you select a geographic-region bandwidth or cross-geographic-region bandwidth, you also need to select geographic region(s) and specify the regions that need to communicate with each other.
    Billed By
    Mandatory
    The price of a global connection bandwidth varies by its size.
    • After a bandwidth is purchased, the billing starts immediately regardless of whether the bandwidth is used.
    • If a bandwidth is no longer required, delete it in a timely manner to avoid unnecessary fees.
    Bandwidth
    Mandatory
    Select the bandwidth, in Mbit/s.
    Bandwidth Name
    Mandatory
    Enter the name of the bandwidth. The name:
    • Must contain 1 to 64 characters.
    • Can contain letters, digits, underscores (_), hyphens (-), and periods (.).
    Enterprise Project
    Mandatory
    Provides a cloud resource management mode, in which cloud resources and members are centrally managed by project.
  4. Click Next.
  5. Confirm the configurations and click Submit.
    The global connection bandwidth list page is displayed.
  6. In the global connection bandwidth list, view the status of the bandwidth.
    If the bandwidth status is Normal, the purchase is successful.
