Deleting or Unsubscribing from a Shared Bandwidth
You can delete a pay-per-use shared bandwidth or unsubscribe from a yearly/monthly shared bandwidth if it is no longer needed. This section describes how to delete or unsubscribe from a shared bandwidth.
Notes and Constraints
If you want to delete or unsubscribe from a shared bandwidth with EIPs added, you have to remove the EIPs from the shared bandwidth first. For details, see Adding EIPs to or Removing EIPs from a Shared Bandwidth.
Deleting a Pay-per-Use Shared Bandwidth
- Go to the shared bandwidth list page.
- In the shared bandwidth list, locate the row that contains the pay-per-use shared bandwidth you want to delete, click More in the Operation column, and then click Delete.
- Confirm the deletion as prompted. Click OK.
Unsubscribing from a Yearly/Monthly Shared Bandwidth
- In the shared bandwidth list, locate the row that contains the yearly/monthly shared bandwidth you want to delete, choose More > Unsubscribe in the Operation column. The unsubscription page is displayed.
- Confirm the information and click Confirm. A confirmation dialog box is displayed.
- Confirm the information and click OK.
Return to the shared bandwidth list and check whether the target shared bandwidth is unsubscribed from.
Related Operations
- Adding EIPs to or Removing EIPs from a Shared Bandwidth: After a shared bandwidth is assigned, you can add multiple pay-per-use EIPs to it so that all EIPs share the same bandwidth.
- Modifying a Shared Bandwidth: You can change the size of the shared bandwidth you have assigned.
- Viewing Bills of a Specific Resource: After a shared bandwidth is used, you can view its bills.
