- What's New
- Billing
- Getting Started
User Guide
- Getting Started with EG
- Permissions Management
- Event Sources
- Event Channels
- Event Subscriptions
- Event Streams
- Events
- Event Rules
- Event Targets
- Network Management
- IAM Projects and Enterprise Projects
- Authorization
- Event Monitoring
- Auditing
- How Is EG Billed?
- Why Did My Event Source Creation Fail?
- How Do I Configure a Security Group When Creating an Event Source?
- Why Did My Event Publishing Fail?
- Why Was the Target Not Triggered?
- Can I Push Custom Events to EG?
- How Do I Filter Events to Transmit to the Target?
- How Do I Transfer Custom Event Content to the Target?
- How Do I Obtain the SASL Certificate Address of a DMS for Kafka Instance?
- SDK Reference
Show all
Configuring DMS for Kafka as the Event Source
Configure a DMS for Kafka instance as the source of an event stream.
- Log in to the EG console.
- In the navigation pane, choose Event Streams.
- Click Create Event Stream.
- Enter an event stream name and description, and click OK.
- Configure a Kafka event source.
- Click Event Source.
- Select Distributed Message Service (DMS) for Kafka for Event Provider.
- Set event source parameters.
Figure 1 Kafka event source
Table 1 Kafka parameters Parameter
Instance
Select a Kafka instance.
Access Mode
Select Ciphertext Access or Plaintext Access.
Security Protocol
If you select Ciphertext Access for Access Mode, the corresponding security protocol will be displayed.
Topic
Select a topic.
Consumer Group
Enter a group name.
Concurrency
Enter the number of concurrent messages. Range: 1–1000.
This parameter is autofilled with the number of partitions for the selected topic. Recommended: retain this default number.
Consumption Offset
Select a consumption offset.
- Latest: Consumption starts from the latest message in the queue.
- Earliest: Consumption starts from the earliest message in the queue.
SASL Mechanism
This parameter is available when SASL_SSL authentication is enabled for the Kafka instance. Select an SASL authentication mechanism.
- PLAIN: a simple username and password verification mechanism.
- SCRAM-SHA-512: uses the hash algorithm to generate credentials for usernames and passwords to verify identities. SCRAM-SHA-512 is more secure than PLAIN.
SASL Certificate URL
This parameter is available when SASL_SSL authentication is enabled for the Kafka instance. Enter an SASL certificate URL.
SASL Certificate Key
This parameter is available when SASL_SSL authentication is enabled for the Kafka instance. Enter an SASL certificate key.
Username
This parameter is available when SASL_SSL authentication is enabled for the Kafka instance. Enter a username.
Password
This parameter is available when SASL_SSL authentication is enabled for the Kafka instance. Enter a password.
- Click Save.
- Configure an event target by referring to Routing to FunctionGraph.
- After the event source and target are configured, click Save in the upper right.
