Login Overview (Windows)
After an ECS is created, you can log in to the ECS and deploy websites or applications on it. Before logging in to an ECS, you need to establish a connection between the local device and the ECS. The connection method depends on the ECS OS and the tool used by the local device.
This section describes the tools and requirements for connecting to a Windows ECS in different methods. You can select a proper method to log in to a Windows ECS as needed.
- You can only log in to a running ECS.
- The username for logging in to a Windows ECS is Administrator.
- If the login password is forgotten, reset the password on the ECS console.
To reset a password, locate the row containing the target ECS and choose More > Reset Password in the Operation column. For details, see Resetting the Password for Logging In to an ECS on the ECS Console.
- If an ECS uses key pair authentication, use the Get Password function on the management console to parse the private key file used during ECS creation into a password, and then use the password to log in to the ECS.
For details, see Obtaining the Password for Logging In to a Windows ECS.
- Certain G-series ECSs do not support remote login provided by the cloud platform. If you need to remotely log in to the ECSs, install the VNC server on them. For details, see GPU-accelerated ECSs. You are advised to log in to such ECSs using MSTSC.
- If you log in to a GPU-accelerated ECS using MSTSC, GPU acceleration will fail. This is because MSTSC replaces the WDDM GPU driver with a non-accelerated remote desktop display driver. In such a case, you must log in to the ECS using other methods, such as VNC. If the remote login function provided by the management console cannot meet your service requirements, you must install a suitable remote login tool, such as TightVNC, on the ECS.
To download TightVNC, log in at https://www.tightvnc.com/download.php.
Login Modes
You can choose from a variety of login modes based on your local OS type.
| Login Mode | Local OS | Tool | Local Software Installation | EIP | Login Credentials |
| (Recommended) Logging In to a Windows ECS Using an RDP File | Windows | RDP file | Required | Required | Password |
| Windows | VNC | Not required | Not required | Password | |
| Windows | MSTSC (System-provided remote desktop connection tool) | Not required | Required | Password | |
| Linux | Remote connection tool (third-party) | Required | Required | Password | |
| macOS | Remote connection tool (third-party) | Required | Required | Password | |
| Mobile terminal | Remote connection tool (third-party) | Required | Required | Password |
