Logging In to a Linux ECS Using an SSH Password
This section describes how to use an SSH password to remotely log in to a Linux ECS from a Windows and a Linux server, respectively.
- The target ECS is running.
- You have bound an EIP to the ECS. For details, see Binding an EIP.
- If you set Login Mode to Set password later or Key pair when purchasing the ECS, you have obtained the login password by resetting it. For details, see Resetting the Password for Logging In to an ECS on the ECS Console.
- Access to port 22 is allowed in the inbound direction of the security group that the ECS belongs to. For details, see Configuring Security Group Rules.
- The network connection between the login tool (PuTTY) and the target ECS is normal. For example, the default port 22 is not blocked by the firewall.
Logging In to a Linux ECS from a Local Windows Server
To log in to a Linux ECS from a local Windows server, perform the operations below.
The following operations use PuTTY as an example to log in to the ECS.
- Visit the following website and download PuTTY and PuTTYgen:
https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
- Run PuTTY.
- Choose Session.
- Host Name (or IP address): Enter the EIP bound to the ECS.
- Port: Enter 22.
- Connection type: Click SSH.
- Saved Sessions: Enter the task name, which can be clicked for remote connection when you use PuTTY next time.
Figure 1 Session
- Choose Window. Then, select UTF-8 for Received data assumed to be in which character set: in Translation.
- Click Open.
If you log in to the ECS for the first time, PuTTY displays a security warning dialog box, asking you whether to accept the ECS security certificate. Click Yes to save the certificate to your local registry.
- After the SSH connection to the ECS is set up, enter the username and password as prompted to log in to the ECS.
If the message "Welcome to Huawei Cloud Service" is displayed, the login is successful.
The username and password for the first login to the ECS created using a public image (including CoreOS) are as follows:- Username: root
- Password: the one you set when you purchased the ECS
If you did not set a password when purchasing the ECS, see Resetting the Password for Logging In to an ECS on the ECS Console.
Logging In to a Linux ECS from a Local Linux Server
To log in to a Linux ECS from a local Linux server, perform the operations below.
- On the Linux CLI, run the following command to log in to the ECS:
xx.xx.xx.xx indicates the EIP bound to the ECS.
- Verify the SSH fingerprint of the ECS and enter yes.
The authenticity of host 'xx.xx.xx.xx (xx.xx.xx.xx)' can't be established. ECDSA key fingerprint is SHA256:rnKuzrUSYS03MCoaxxxxxxxxxxxxxxxxxxxxxxxxxxx. ECDSA key fingerprint is MD5:cf:64:5b:5e:74:30:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx. Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added 'xx.xx.xx.xx' (ECDSA) to the list of known hosts.
- Enter the password for logging in to ECS.
root@xx.xx.xx.xx's password: Welcome to Huawei Cloud Service
