Binding a Global EIP
Global EIPs provide global internet access for cloud instances. You can specify a global region and a global EIP pool to assign a global EIP, and bind the global EIP to a cloud instance from any region to enable communications between a cloud resource and the Internet.
You can create a global EIP and bind it to an ECS so that the ECS can access the Internet.
This section describes how to bind a global EIP to an ECS.
- A global EIP can only be bound to one ECS at a time. Multiple ECSs cannot be bound to the same global EIP.
- After a global EIP is bound to an ECS, the VPC of the ECS cannot be changed, and no more EIP can be bound to the ECS.
- To bind an IPv6 global EIP to an ECS, ensure that IPv6 is enabled for the ECS to support both IPv4 and IPv6 addresses. For details, see Enabling IPv6 for a Network Interface.
- Global EIPs cannot be bound to frozen ECSs.
Before binding a global EIP to an ECS, complete the following operations:
- You have bought a global internet bandwidth to connect the global EIP to the Internet.
- You have bought a global connection bandwidth for communication over the backbone network.
- You have created a global internet gateway to connect the VPC of the ECS to the global EIP.
- You have assigned a global EIP to the ECS to access the Internet.
- Log in to the ECS console and access the ECS list page.
- In the ECS list, select the target ECS and choose More > Manage Network > Bind Global EIP in the Operation column.
- Locate the target global EIP, and click Bind Instance in the Progress column.
The page for binding an instance is displayed.
- Select the region that the instance to be bound is located.
- Select the type of the instance to be bound and then select the instance.
- Select the global internet gateway to be bound.
The system automatically lists the global internet gateway of the VPC that the instance belongs to, if there is one.
- Click Next.
- Configure Global Connection Bandwidth, Bandwidth Name, and Bandwidth as prompted.
If there is no global connection bandwidth, click Manage Global Connection Bandwidth to create one. For details, see Buying a Global Connection Bandwidth.
- Click OK.
In the global EIP list, you can see that the global EIP has an instance bound.
Related Operations
