Creating a Launch Template
A launch template contains the information required to quickly launch an ECS, for example, the ECS specifications, network settings, and a key pair (excluding the password). You can launch an ECS quickly without specifying the configuration parameters every time.
This section describes how to create a launch template on the management console.
- Each account can have a maximum of 30 launch templates in each region.
- The parameters you can configure when you create a launch template are optional.
However, if your launch template does not include parameters, such as the flavor and image, you need to set them when you use the template to create an ECS.
- The configuration cannot be saved as a launch template if the billing mode is yearly/monthly or spot block, host security is enabled, or the login mode is password.
- After a launch template is created, it cannot be modified.
You can create multiple launch templates as required, with each configured with different parameters.
- Currently, launch templates are supported in AP-Singapore and CN-Hong Kong.
Creating a Launch Template When Buying an ECS
You can save the ECS configurations as a launch template when creating an ECS.
- Click
in the upper left corner and select a region and project. - Click
. Under Compute, choose Elastic Cloud Server. - Click Buy ECS.
- On the Custom Config tab, set the required parameters.
For details about the parameters, see Purchasing an ECS in Custom Config Mode.
- In the Configuration Summary panel on the right side, review the ECS configuration details.
Unspecified mandatory fields are displayed in red. You need to set them in the parameter configuration area.
- In the Configuration Summary panel, click Save as Launch Template.
Some parameter values cannot be saved to the launch template. The system will automatically convert those values. For details, see Savable Launch Settings.
- Read the agreement and click Agree and Submit.
- In the displayed dialog box, enter a launch template name and description, and click OK.
You can view the created template on the launch template list page.
Creating a Launch Template on the Launch Templates Console
- Click
. Under Compute, choose Elastic Cloud Server. - In the navigation pane on the left, choose Launch Templates.
- On the Launch Templates page, click Create Launch Template.
- On the Create Launch Template page, configure the required parameters.
- Read and agree to the agreement, and click Create Now.
Go back to the launch template list and you can view the created launch template.
When you use a launch template in custom config mode to launch ECSs, some parameter values cannot be saved to the template. The system will automatically convert those values.
| Module | Parameter | Setting | Savable to Launch Template | Value Converted When Saved to Launch Template | Value Saved in Launch Template |
| Basic Configuration | Billing Mode | Yearly/Monthly | Yes | Yes | Pay-per-use |
| Pay-per-use | Yes | No | Pay-per-use | ||
| Spot pricing - Spot | Yes | No | Spot pricing - Spot | ||
| Spot pricing - Spot block | Yes | Yes | Pay-per-use | ||
| Region | Select a region | Yes | Yes | The region that the launch template belongs to | |
| AZ | Random | Yes | No | Random | |
| Select an AZ | Yes | Yes | The AZ that the launch template belongs to | ||
| Edge AZ | No | No | N/A | ||
| Randomly allocated to multiple AZs | No | No | N/A | ||
| Instance | Specifications | Select specifications | Yes | No | The specifications you selected |
| OS | Image | Select an image | Yes | No | The image you selected |
| Host protection (HSS) | Enable | No | No | Disabled by default. | |
| Application acceleration | Enable | No | No | Disabled by default. | |
| Enclave | Enable | No | No | Disabled by default. | |
| Storage & Backup | System/Data Disk | Select a disk type | Yes | No | The disk type you selected |
| Specify the disk size | Yes | No | The disk size you specified | ||
| Select Encryption | Yes | No | Encryption enabled | ||
| Specify the KMS key name/ID | Yes | No | The KMS key name/ID you specified | ||
| Disk type (VBD/SCSI) | No | No | N/A | ||
| Storage type (EVS/DSS) | No | No | N/A | ||
| Storage pool ID | No | No | N/A | ||
| IOPS/Throughput | No | No | N/A | ||
| Select Sharing | No | No | N/A | ||
| Select Release with ECS | No | No | N/A | ||
| Select Create Disk from Data Disk Image | No | No | N/A | ||
| Cloud Backup and Recovery | Create new/Use existing/Disable backup | No | No | N/A | |
| Backup Policy | No | No | N/A | ||
| Vault Capacity | No | No | N/A | ||
| Cloud Backup Vault | No | No | N/A | ||
| Network | VPC | Select a VPC | Yes | No | The VPC you selected |
| Primary NIC | Select a subnet | Yes | No | The subnet you selected | |
| Automatically assign IP address/Manually specify IP address | No | No | Automatically assign IP address | ||
| IPv6 not required/Automatically-assigned IPv6 address | No | No | IPv6 not required/Automatically-assigned IPv6 address | ||
| Bind a shared bandwidth | No | No | No shared bandwidth | ||
| Source/Destination Check | No | No | N/A | ||
| Security Group | Select a security group | Yes | No | The security group you selected | |
| Public Network Access | EIP | Select an EIP type | Yes | No | The EIP type you selected |
| Select Bandwidth for Billed By | Yes | No | Billed by bandwidth | ||
| Specify the bandwidth size | Yes | No | The bandwidth size you specified | ||
| Select Shared bandwidth for Billed By and select a bandwidth name | Yes | No | The bandwidth name you selected | ||
| EIP Pool | No | No | N/A | ||
| Use existing | No | No | N/A | ||
| Select Release with ECS | No | No | Deselected by default | ||
| Instance Management | ECS Name | Specify an ECS name | Yes | No | The ECS name you specified |
| Select Allow duplicate name | No | No | N/A | ||
| Login Mode | Password | No | No | Set password later | |
| Key pair | Yes | No | The key pair you selected | ||
| Set password later | Yes | No | Set password later | ||
| Password from image | No | No | Use the image password. The password is empty. | ||
| Enterprise Project | Specify an enterprise project | Yes | No | The enterprise project you selected | |
| Tag | Add a tag | Yes | No | The tag you added | |
| Advanced Settings | Detailed monitoring | Enable | Yes | No | Detailed monitoring enabled |
| ECS group | Select ECS group | No | No | N/A | |
| ECS Description | Enter a description | Yes | No | The description you entered | |
| User Data | Inject user data | Yes | No | The data you injected | |
| Agency | Select an agency | Yes | No | The agency you selected | |
| Metadata Access | Enable | No | No | N/A | |
| Metadata Version | Only V2 (Token) | No | No | N/A | |
| CPU Options | Select Specify CPU options | No | No | N/A | |
| Purchase Details | Required Duration | Select Set scheduled deletion time | No | No | N/A |
| Required Duration | 1 month | No | No | N/A | |
| Auto-renew | Enable | No | No | N/A | |
| Quantity | 1 | No | No | N/A |
