Overview
A tag identifies an ECS. Adding tags to an ECS facilitates ECS identification and management.
- In the Tag column of the ECS list, click Edit Tag and add tags to an ECS.
- On the Tags tab of the ECS details page, click Add Tag to add tags to an ECS.
Tags added during the ECS creation will also be added to the EIP and EVS disks (including the system disk and data disks) of the ECS. If the ECS uses an existing EIP, the tags will not be added to the EIP.
Tags added after the ECS creation will also be added to the EIP and EVS disks (including the system disk and data disks) associated with the ECS.
If your organization has created tag policies for the ECS, you need to add tags based on the tag policies. If any tag does not comply with the tag policies, the ECS creation may fail. Contact the organization administrator to learn more about the tag policies.
After creating the ECS, you can view the tags on the pages providing details about the ECS, EIP, and EVS disks.
Basics of Tags
Tags are used to identify cloud resources. When you have many cloud resources of the same type, you can use tags to classify cloud resources by dimension (for example, usage, owner, or environment).
Figure 1 shows how tags work. In this example, you assign two tags to each cloud resource. Each tag contains a key and a value that you define. The key of one tag is Owner, and the key of another tag is Usage. Each tag has a value.
You can quickly search for and filter specific cloud resources based on the tags added to them. For example, you can define a set of tags for cloud resources in an account to track the owner and usage of each cloud resource, making resource management easier.
Tag Naming Rules
- Each tag consists of a key-value pair.
- A maximum of 20 tags can be added to an ECS.
- For each resource, a tag key must be unique and can have only one tag value.
- A tag consists of a tag key and a tag value. Table 1 lists the tag key and value requirements.
Table 1 Tag key and value requirements Parameter
Requirement
Example Value
Key
- Cannot be left blank.
- The key value must be unique for an ECS.
- Can contain a maximum of 128 characters.
- Cannot contain the following special characters: =*<>\,|/
- Cannot be started or ended with a space.
Organization
Value
- Can contain a maximum of 255 characters.
Apache
