Adding a Yearly/Monthly EVS Disk
You are allowed to add yearly/monthly EVS disks to a yearly/monthly ECS. The expiration time of the newly added EVS disks is the same as that of the ECS.
- A maximum of 60 disks can be attached to an ECS.
The number of disks that can be attached to an ECS varies depending on the ECS flavor and disk type. For details, see Can I Attach Multiple Disks to an ECS?
- The new disks can be attached to an ECS only as data disks.
- The new data disks must be in the same region and AZ as the ECS.
- The new data disks must use the same billing mode as the ECS.
- For details about the new disk types and their performance, see Disk Types and Performance.
- Click
in the upper left corner and select a region and project. - Click
. Under Compute, click Elastic Cloud Server. - In the search box above the ECS list, enter the ECS name, IP address, or ID for search.
- Click the name of the target ECS.
The ECS details page is displayed.
- Click the Disks tab. Then, click Add Disk.
The system switches to the EVS disk purchase page.
- Configure parameters for the new EVS disk as prompted.
- Click Next.
- Verify that the disk is correctly configured, select the agreement, and click Submit.
The new EVS disk is automatically attached to the target ECS.
After the new disk is detached, it can only be attached to the original ECS.
