- What's New
- Function Overview
- Getting Started
User Guide
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Intelligent Resolution
- Resolver
- Permissions Management
- Using CTS to Collect DNS Key Operations
- Access Logging
- Quota Adjustment
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs
- Examples
- Appendix
- SDK Reference
DNS Overview
- Will I Be Billed for the DNS Service?
- How Many Zones, PTR Records, and Record Sets Can I Create?
- What Are Huawei Cloud DNS Servers?
- What Are Huawei Cloud Private DNS Server Addresses?
- What Are the Differences Between Public and Private Domain Names?
- Does DNS Support IPv6?
- Does DNS Support Explicit Forwarding and Implicit Forwarding?
- Does DNS Support Dynamic Domain Name Resolution?
- Does DNS Support Wildcard Entries?
- What Is TTL?
- How Many Domain Name Levels Does DNS Support?
- How Are Zones Queried to Resolve a Domain Name?
- What Are the Priorities of Resolution Lines?
- Why Was the Email Address Format Changed in the SOA Record?
- What Is CAA?
- Why Should I Set Priority For an MX Record Set?
- Can DNS Point a Domain Name to a Specific Port?
- Invalid Domain Resolution
- Website Access Failures
Public Zones
- Why Is a Message Indicating Conflict with an Existing Record Set Displayed When I Add a Record Set?
- How Do I Handle the Conflict Between CNAME and MX Record Sets?
- How Do I Add Record Sets to Subdomains?
- Which IP Address Is Returned for the Domain Name If There Are Multiple IP Addresses in a Record Set?
- Can I Modify a Zone?
- Can DNS Translate a Domain Name to IP Addresses of On-premises Servers or Third-Party Servers?
- How Can Multiple Domain Names Be Linked to the Same Website?
- Configuring Weighted Routing
- Can DNS Resolve a Domain Name that Has Not Been Licensed?
- How Do I Change the DNS Servers of a Domain Name?
- How Do I Handle Inaccurate Scheduling Caused by the CNAME Record Set Cache in the Default Lines?
Private Zones
- How Do I Change Default DNS Servers of an ECS to Huawei Cloud Private DNS Servers?
- How Can I Access an ECS Using Its Host Name?
- How Can I Map the Private IP Address of an ECS to a Domain Name?
- How Can I Use a Private Domain Name to Route Internet Traffic?
- Can I Use Private Domain Names Across Regions?
- Do I Need to Register Private Domain Names?
- Will a Deleted VPC Be Automatically Disassociated from the Private Zone?
- Are Private DNS Server Addresses the Same for All Users?
- What Are the Restrictions on Concurrent Private DNS Queries?
- Reverse Resolution
- Domain Transfer
DNS Overview
- Videos
More Documents
- Overview
- Getting Started
- Private Zone
- Record Set
- PTR Record
- Key Operations Recorded by CTS
- Quota Adjustment
- FAQs
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
- Getting Started
- Public Zones
- Private Zones
- Record Sets
- PTR Records
- Quota Adjustment
FAQ
DNS Overview
- What Are DNS Servers?
- Does DNS Support Explicit and Implicit URLs?
- What Is TTL?
- What Is CAA?
Public Zones
- What Can I Do If There Is Message Indicating that the Public Zone Already Exists?
Private Zones
- What Are the Restrictions on Concurrent Private DNS Requests?
DNS Overview
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Private Zone
- Record Set
- Quota Adjustment
DNS Overview
- How Many Zones and Record Sets Can I Create?
- What Are the Private DNS Servers Provided by the DNS Service?
- Private Zones
DNS Overview
- Change History
- API Reference (Kuala Lumpur Region)
- User Guide (Ankara Region)
- API Reference (Ankara Region)
- Glossary
Show all
Public Zone Overview
A public zone provides information to translate a domain name and its subdomains into IP addresses required for network communications over the Internet. Visitors can access your website by entering a domain name in the address box of a browser. To use Huawei Cloud DNS for public domain name resolution, create a public zone for your domain name, and add record sets to map your domain name to one or more IP addresses.
Table 1 describes the operations required for creating and managing public zones.
Operation |
Scenario |
Constraints |
Create a zone for your domain name. |
Modify, delete, enable, disable, and view public zones. |
Reclaim a public zone by proving that you are the holder of the domain name to Huawei Cloud when message "This public zone has been created by another account" is displayed when you create a public zone. |
Use digital signatures to ensure the authenticity and integrity of DNS response packets, protect end users from being redirected to unexpected addresses, and prevent attacks such as DNS spoofing and cache pollution. |
