Updated on 2026-05-26 GMT+08:00
Changing the Database Owner on the DLI Console
In practical use, developers create databases and tables, which are then handed over to testers for testing. Once testing is complete, the databases and tables are handed over to O&M personnel for experience. In this scenario, ownership of the data can be transferred to another owner by changing the database owner.
You can change the owner of a database on either the Data Management page or the SQL Editor page.
  • On the Data Management page, change the database owner.
    1. Log in to the DLI management console.
    2. In the navigation pane, choose Data Management > Databases and Tables.
    3. On the Databases and Tables page, locate the database you want and click More > Modify Database in the Operation column.
    4. In the displayed Modify Owner dialog box, enter a new owner name (an existing username) and click OK.
  • Change the database owner on the SQL Editor page.
    2. In the navigation pane, choose SQL Editor.
    3. In the navigation tree on the left, click Databases, click on the right of the database you want to modify, and choose Modify Database from the shortcut menu.
    4. In the displayed dialog box, enter a new owner name (an existing username) and click OK.
