Updated on 2025-08-15 GMT+08:00
Deleting a Database on the DLI Console
You can delete an unused database from the DLI console: when a database is no longer needed, such as after a test database has completed testing; if a database has errors or anomalies that cannot be fixed; when there is a need to reorganize the data structure, such as by modifying table designs; or if a database is idle and has no practical use.
This section describes how to delete a database on the DLI management console.
Precautions
  • Databases or tables that are being used for running jobs cannot be deleted.
  • The administrator, database owner, and users with the database deletion permission can delete the database.
    If a database or table is deleted, it cannot be recovered. Exercise caution when performing this operation.
Deleting a Database
  1. In the navigation pane on the left of the console, choose Data Management > Databases and Tables.
  2. Locate the row where the target database locates and click More > Drop Database in the Operation column.
    You cannot delete databases that contain tables. To delete a database containing tables, delete the tables first.
  3. In the displayed dialog box, click Yes.
