- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
On this page
Show all
Help Center/
Data Lake Factory/
User Guide/
Data Management/
Database Schemas/
Creating a Database Schema
After creating a DWS data connection, you can manage the database schemas under the DWS data connection in the area on the right.
- A DWS data connection has been created. For details, see Creating a Data Connection.
- A DWS database has been created. For details, see Creating a Database.
- Log in to the DLF console.
- In the navigation tree of the Data Development console, choose Data Development > Develop Script/Data Development > Develop Job.
- In the menu on the left, click
. Click a DWS data connection and choose a desired database. Right-click schemas, and choose Create Schema from the shortcut menu.
- In the displayed dialog box, configure schema parameters. Table 1 describes the database schema parameters.
- Click OK.
Parent topic: Database Schemas
