Creating an Alias for a Custom Key
An alias is an identifier of a key. You can use the alias as the key ID during API calling. The original key alias is not used as the key name.
This section describes how to add and delete an alias for a key.
- An alias can be used for only one key. A key can have multiple aliases.
- The aliases are unique in a region but can be the same in different regions.
- The aliases cannot be modified once being created.
- A maximum of 50 aliases can be created for a key.
- Log in to the DEW console.
- Click
in the upper left corner and select a region or project. - Click the target key name. On the key details page, click the Alias tab.
- Click Create Alias. Enter the alias in the displayed dialog box and click OK.
Only digits, letters, underscores (_), hyphens (-), colons (:), and slashes (/) are allowed.
Deleting an Alias
- Click
- Locate the target alias and click Delete in the Operation column.
- Enter DELETE in the confirmation dialog box if deletion verification is disabled and click OK.
If you have enabled deletion verification, select a verification mode, click Get Code, enter the code, and click OK.
To disable operation protection, go to the Security Settings page, click Disable next to Operation Protection in the Critical Operations tab, or click Disable Operation Protection on the deletion page.
Related Operations
Create an alias using an API. For details, see Creating a Key Alias.
