- Billing
- Getting Started
User Guide
- Preparations
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
Best Practices
- Best Practices Summary
Using CodeArts to Manage an e-Mall Development Project
- Overview
- Resource Planning
- Process
Implementation Procedure
- Preparation
- Step 1: Managing Project Plans
- Step 2: Managing Project Configurations
- Step 3: Writing Code
- Step 4: Checking Code
- Step 5: Building an Application
- Step 6: Deploying an Application (CCE)
- Step 6: Deploying an Application (ECS)
- Step 7: Managing Project Tests
- Step 8: Configuring a Pipeline for Continuous Delivery
- Releasing Resources
General
- How Do I Collect or Archive Project Information Locally After a CodeArts Project Is Complete?
- Why Can't an IAM User View Any CodeArts Projects After Login?
- How Do I View All CodeArts Projects and Members Under My Account as Administrator?
- Will the Tasks Created by a Project Member Be Deleted After the Member Leaves the Project?
- Will a New User with the Same Name as a Deleted User Inherit Their Permissions and Tasks?
- CodeArts Req
- CodeArts Repo
- CodeArts Pipeline
- CodeArts Check
- CodeArts Build
- CodeArts Artifact
- CodeArts Deploy
- CodeArts TestPlan
- CodeArts PerfTest
General
- Videos
Show all
Creating and Authorizing a User
You can use Identity and Access Management (IAM) to implement fine-grained permissions control for your CodeArts console. With IAM, you can:
- Use your account to create IAM users for employees based on the organizational structure of your enterprise. Each IAM user has their own security credentials for accessing CodeArts resources.
- Assign only the permissions required for users to perform a specific task.
If your account does not require individual IAM users, skip this section.
This section describes the procedure for granting permissions (see Figure 1).
Learn about the permissions supported by CodeArts and choose permissions according to your requirements. For the permissions of other services, see System Permissions.
Process
- Create a user group and assign permissions.
Create a user group on the IAM console, and attach the DevCloud Console ReadOnlyAccess policy to the group.
- Create an IAM user and add it to a group.
Create a user on the IAM console and add the user to the group created in 1.
- Log in and verify permissions.
Log in to the console as the created user and switch to the region for which the user is authorized to verify permissions.
Choose CodeArts in Service List, and then choose Enterprise Account Authorization in the navigation pane. Click Authorize Enterprise Account, and enter an account ID. If a message is displayed indicating that you cannot access the page, the DevCloud Console ReadOnlyAccess policy has already taken effect.
