Updated on 2026-08-11 GMT+08:00
Setting DingTalk Subscriptions
When any of the following events occurs, CodeArts sends a message through HTTP to the DingTalk group that has subscribed to the event.
Table 1 Event types
Category
Event types
Raw requirement
Create/Submit
Edit
Delete
Change
Update status
Ticket reminder added
Comment
System feature (SF)
Create
Edit
Delete
Change
Baseline/Unbaseline
Update status
Comment
R&D requirement (IR/SR/AR)
Create
Edit
Delete
Change
Baseline/Unbaseline
Move
Comment
Update status
Task
Create
Edit
Delete
Comment
Update status
Bug
Create/Submit
Edit
Delete
Move
Update status
Comment
Review
Submit
Transfer to others
Cancel/Reject
Change object reviewed
Change object decision-making completed
Review or decision-making completed
Delete
Comment
Table 2 Event types
Category
Event types
Repository
Capacity warning
Repo deleted
MR
MR opened
MR updated
MR merged
MR reviewed
MR approved
Review created
Review comment resolved
Table 3 Event types
Event Type
Notification Content
Completed
  • Pipeline name
  • Pipeline execution description
  • Executor
  • Trigger
  • Project name
  • Execution time
  • Running status
Failed
Paused
Suspended
Ignored
Table 4 Event types
Event Type
Check task
Completed
  • All
  • Gate check passed
  • Gate check failed
  • Check result
  • Gate check result
  • Number of issues
  • Redirect URL
  • Executor
  • Completion time
Table 5 Event types
Event Type
Build task
Task successful
  • Task name
  • Executor
  • Execution time
Task failed
Task disabled
Task deleted
Task configurations updated
Table 6 Event types
Event types
Application
Application deployed
  • Application name
  • Execution result
  • Execution ID
  • Executor
  • Execution time
  • Project name
Deploy application failed
Deploy stopped
  • This function is now available in the AP-Singapore region.
  • CodeArts Req configuration is only available for IPD projects.
You have created a CodeArts project, and your role in the project is Project Administrator or Project Manager.
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region where you have enabled CodeArts.
    2. Click Go to Workspace.
      If your account uses the old billing mode (see Old Billing Modes), click Access Service.
  2. Click the target project name to go to the project.
  3. In the navigation pane, choose Settings > General > Notifications.
  4. Click the DingTalk tab.
  5. Set parameters as required.
    Figure 1 Configuring DingTalk notifications (CodeArts Pipeline is used as an example.)
    Table 7 Setting DingTalk subscriptions
    URL
    The webhook URL of your DingTalk robot. Start with http:// or https://. The URL cannot exceed 256 characters.
    Event types
    Event types that can trigger a DingTalk notification. For details about the supported event types, see Scenario.
    Notification content
    Content of the DingTalk notification. For details about the configurable content, see Scenario.
    Optional. Configure it if the specific content notification is needed.
    @user_id
    DingTalk user IDs of the members you want to mention. Separate the IDs with semicolons (;). The total IDs cannot exceed 1,000 characters. Digits, letters, semicolons (;), periods (.), hyphens (-), underscores (_), and at signs (@) are supported.
    Optional. Configure it if you need to notify a specified member.
    @Mobile numbers
    Optional. Mobile numbers of the members you want to mention. Separate mobile numbers with semicolons (;). The total mobile numbers cannot exceed 1,000 characters. Digits and semicolons (;) are supported.
    Secret
    Optional. If your DingTalk robot has enabled signature-based encryption in security settings, enter the signing secret with a maximum of 2,000 characters.
  6. After the configuration is complete, you can perform the following operations:
    • Click Save to save the configuration.
      • : The DingTalk subscription configuration is saved but does not take effect. It will take effect only after the switch is toggled on.
      • : The DingTalk subscription configuration takes effect immediately.
      Figure 2 Applying configurations
    • Click Save and Enable Notification. The DingTalk subscription configuration takes effect immediately.
    • Click Cancel to cancel the configuration. The values of the parameters on the page are restored to the last saved settings. If this is the first configuration, all parameter values on the page are cleared.
