Setting Email Notifications
CodeArts sends an email to the specified recipients when any of the following events occurs.
| Event types | Recipient | |
| CodeArts Pipeline | Pipeline deleted |
| Execute pipeline failed | ||
| Pipeline executed | ||
| Pipeline updated | ||
| Event Type | Recipient | |
| Check task | Task completed |
| Gate check failed | ||
| Task deleted |
| Build task | Task successful |
| Task failed | ||
| Task disabled | ||
| Task deleted | ||
| Task configurations updated | ||
| Application | Application deployed |
| Deploy application failed | ||
| Application updated | ||
| Application deleted | ||
This function is now available in the AP-Singapore region.
- You have created a CodeArts project, and your role in the project is Project Administrator or Project Manager.
- The recipients will receive emails only if they have enabled email notifications and set a valid email address as described in Setting Notification Receiving Rules.
- Go to the CodeArts homepage.
- Log in to the CodeArts console, click
, and select a region where you have enabled CodeArts. - Click Go to Workspace.
If your account uses the old billing mode (see Old Billing Modes), click Access Service.
- Click the target project name to go to the project.
- In the navigation pane, choose Settings > General > Notifications.
- Click the Email tab.
- Specify recipients for each event type and determine whether to enable notifications.
The updated configuration is displayed.
Figure 1 Configuring email notifications (CodeArts Pipeline is used as an example.)
