Help Center/ CodeArts/ User Guide/ Preparations/ Creating a Project
Creating a Project
Updated on 2025-02-12 GMT+08:00
In CodeArts, projects are the basis for using various services. Operations such as requirement planning, code management, build, and deployment must be performed in a CodeArts project.
CodeArts provides multiple preset project templates for different requirement management processes. This section uses the Scrum process as an example to describe how to create a CodeArts project. For more information about preset templates, see Using a Project Template.
To create CodeArts projects, you must have either of the following permissions:
Setting Project Creators
To set CodeArts project creators, you must have the Tenant Administrator role.
  1. Go to the CodeArts homepage.
    1. Log in to the CodeArts console, click , and select a region.
    2. Click Access Service.
  2. Click the username on the navigation bar and choose All Account Settings.
  3. Choose General > Project Creators.
  4. Select Only some members can create projects. The member list is displayed.
  5. Enable or disable the authorization by clicking . Unauthorized members cannot create projects.
Creating a CodeArts Project
  2. On the CodeArts homepage, click Create Project and select Scrum.
    If there is no project on the homepage, click Select on the Scrum card.
  3. Set the project information and click OK.
    Table 1 Creating a project
    Mandatory
    Project Template
    Yes
    Select a built-in or custom template. For details about how to configure a template, see Configuring Common Settings.
    Name
    Yes
    Enter a maximum of 128 characters.
    Project Code
    No
    Enter a maximum of 200 characters, including digits, letters, hyphens (-), and underscores (_).
    No
    Enter a maximum of 1,024 characters.
  4. Check the project information.
Follow-up Operations
After you create a CodeArts project, members with the edit permission on the project can choose Settings > General in the navigation pane and perform the following operations.
Table 2 Managing a CodeArts project
Operation
Remarks
Modifying basic information
  1. Choose Basic Information.
  2. Modify the project name, code, and description as required, and click Save.
    The modified information is displayed.
Transferring the project creator
  2. Select the member to transfer the project to from the Creator drop-down list, and click Save.
    The new creator is displayed.
If the project creator is deleted from IAM, the project ownership is automatically transferred to the project manager. If the project creator is also the project manager, the project ownership is transferred to the administrator account.
Archiving the project
  2. Click Archive.
    Then the button changes to Unarchive.
  • Archived projects are read-only to all members. The members cannot add, delete, or modify work items.
  • Members of archived projects are still counted.
Deleting the project
  2. Click Delete Project, enter the project name, and click Delete.
    The deleted project is no longer displayed on the homepage.
  • Deleting a project will also delete its code repositories, check tasks, build tasks, and test cases.
  • Deleted data cannot be recovered. Exercise caution when performing this operation.
Managing service menus
  1. Choose Services.
  2. Select the menus to display.
  3. Refresh the page. The updated menus are displayed in the navigation pane.
