Quickly Deploying an Application in Kubernetes (CCE Cluster)
This section introduces how to quickly deploy an application in a CCE cluster by upgrading Kubernetes workload images.
A CCE cluster is available. You may be charged during the process. For details, see CCE Billing.
Configuring Deployment Actions
- Create an application by referring to Creating an Application.
- On the Deployment Actions page, add this deployment action based on the service scenario.
- Configure the action using the parameters described in the table below.
Table 1 Parameters Parameter
Action Name
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./()
Tenant
- Current: The software package is deployed in a CCE cluster of the current tenant for release.
Select Current. The current tenant must have the CCE cluster operation permission. If not, enable IAM authorization to select an authorized user from the User drop-down list for deployment.
- Other: The software package is deployed and released in a CCE cluster of another tenant in IAM authorization mode.
After selecting Other, select an authorized tenant.
NOTE:You are advised to configure the AK/SK of a member account that has the CCE cluster operation permission and not advised to configure the AK/SK of a tenant account.
IAM authorization
If you do not have the permission to call CCE APIs, enable this option to obtain the temporary AK/SK of an authorized user.
Region
Select the region to be deployed.
Cluster Name
Select the Kubernetes cluster applied for on CCE.
Namespace
Select the namespace of the Kubernetes cluster on CCE.
Workload
Select the target workload to be deployed.
Only Deployment workloads are supported.
Instances
Enter the number of instances to be deployed.
NOTE:If this parameter is left blank, the current number of pods in the CCE cluster will be adopted.
Container
Select the name of the CCE container to be deployed.
Select the image for deployment.
Image Tag
Select the tag of the image for deployment.
Container Specifications
Configure the specifications of the target container in the target workload.
- CPU Quota
- Request: Minimum number of CPU cores required by a container. Resources are scheduled for the container based on this value. The container can be scheduled to a node only when the total available CPU on the node is greater than or equal to the requested quota.
- Limit: Maximum number of CPU cores required by a container. If the CPU usage is greater than the limit, the CPU resources used by the container may be limited.
- Memory Quota
- Request: Minimum memory size required by a container. Resources are scheduled for the container based on this value. The container can be scheduled to a node only when the total available memory on the node is greater than or equal to the requested quota.
- Limit: Maximum memory size available for a container. When the memory usage exceeds the configured memory limit, the instance may be restarted, affecting normal use of deployment.
Environment Variables
Configure environment variables for the target container in the target workload.
Real-time environment variables are synchronized from CCE to replace the variables on this page.
Java Probes
Locate workload issues and analyze performance bottlenecks. For details, see Configuring APM Settings for Performance Bottleneck Analysis.
Probe Type
- APM 2.0 Probe: Java probes will allocate 0.25-core CPU and 250-MiB memory to initialize containers.
- Disable: Probe-based fault locating is disabled.
When Probe Type is set to APM 2.0 Probe, configure the following parameters:
Probe Version: Select a probe version.
Probe Upgrade Policy: Select Automatic upgrade upon restart or Manual upgrade upon restart.
- Automatic upgrade upon restart: The system downloads the image upon each restart.
- Manual upgrade upon restart: If a local image is available, it will be used. If no local image is available, the system downloads the probe image.
APM Environment: (Optional) Enter the APM environment information.
APM Business: Select an APM application
APM Sub-Business: (Optional) Enter a sub-application.
Access Key Id: The system automatically obtains the relevant secret access key from APM. Go to the APM console to check the key details.
For details about the APM 2.0 parameters, see APM parameters.
Action Control
Continue the task even if this action fails.
Overtime
Maximum execution duration of the action, in minutes. If the duration exceeds the specified time before you stop the action, the action will be timed out. Value range: 1–30.
You can set Container, Image, Image Tag, Instances, and Java Probes (including APM Environment and APM Sub-Businesses) by referencing ${XXX} parameters defined on the Parameters tab. For details, see Parameter Management.
Helpful Links
If you encounter any problem during deployment, see FAQs About Kubernetes Deployment Tasks.
