Help Center/CodeArts Deploy/User Guide/Creating and Deploying an Application Using a Preset Template/Creating and Deploying an Application Using the Tomcat Template
Updated on 2026-01-21 GMT+08:00
You can deploy a WAR package to the Tomcat service on a host and start the service.
  1. In the template selection step, select this system template by referring to Creating an Application Using a System Template.
    The related deployment actions are shown in the following figure. Check whether you have installed Tomcat on the target host. If yes, remove the Install Tomcat action from the template.
  2. On the Deployment Actions page, configure the following actions. For details about the parameters, see below.
  3. Table 1 describes the parameters in the template.
    Table 1 Template parameters
    host_group
    Target environment where the application is deployed.
    package_url
    Software package download link. To obtain it, go to the Artifact > Release Repos page.
    service_port
    Port number of a Tomcat application. The default value is 8080.
    tomcat_home_path
    Path of the Tomcat client. The default value is /usr/local/tomcat/apache-tomcat-8.5.38.
