Deploying to FunctionGraph
In this step, you can deploy software packages in the Artifact, Repo, and OBS to FunctionGraph to release a new version.
You have FunctionGraph operation permissions.
Parameter |
Description |
Action Name |
Custom action name. Enter 1 to 128 characters. Do not start or end with a space. Use letters, digits, spaces, and these special characters: -_,;:./() |
Tenant |
You are advised to configure the AK/SK of a member account with FunctionGraph operation permissions and not advised to configure the AK/SK of a tenant account. |
IAM authorization |
If the current user does not have the FunctionGraph operation permissions, you can use IAM to authorize the user. |
Function |
Functions created in FunctionGraph. For details, see FunctionGraph Usage Process. |
Deployment source |
The deployment source can be Artifact, Repo, or OBS.
Release New Version |
New versions of FunctionGraph can be released. A function can have a maximum of 20 version numbers and each version number must be unique. |
Action Control |
You can configure whether to enable the setting.
If Deployment source is set to Artifact or Repo, the maximum size of a code package is 50 MB. If the size of a code package exceeds 50 MB, you are advised to deploy the code package using OBS.
