Viewing Network Metrics
The DDM console supports monitoring and management of network metrics.
If load balancing is enabled for your DDM instance, you can view network metrics. If load balancing is not enabled, you do not have the permissions to view them.
- Log in to the DDM console.
- In the instance list, locate the required DDM instance and click its name.
- In the navigation pane on the left, choose Monitoring.
- Click Network.
    You can select a time range and view metrics such as inbound rate, outbound rate, , and healthy servers. For details, see Network Metrics. Figure 1 Network monitoring
