- What's New
- Getting Started
- User Guide
- What Is DCC?
- How Is a DCC Billed?
- What Steps Will Be Taken by Huawei Cloud to Handle a Server Fault in a DCC?
- How Do I Select a Region?
- How Is the Memory Allocation Rate in a DCC Computing Resource Pool Calculated?
- FAQs About ECSs
- What Are the Characteristics of ECSs in a DeC?
- How Is an ECS in a DeC Billed?
- API Reference
- Glossary
- More Documents
Expanding DCC Resources
If the DCC resources you have obtained cannot meet your demands, you can expand DCC resources.
- Click the region name in the upper left corner and select the required region.
- Click Service List. Under Compute, click Dedicated Cloud.
- On the DeC page, click DCC resource pool.
The Dedicated Computing Cluster page is displayed.
- In the upper right corner, click Apply for Expansion.
The Apply for Resources page is displayed.
- Locate the server type you want to add, set the desired number in the Quantity column, and select a usage duration.
- Click Next.
- Confirm the configuration and click Submit.
- After the task is successfully submitted, the system generates a payment order.
Once your payment is verified, the administrator will expand your required resources as soon as possible. After the expansion is complete, the order is in the completed state.
